Transmission Holding Device
  • 1748 S
  • Platinum Forum User
31 May 2015 20:40 #29686 by 1748 S
Replied by 1748 S on topic Re: Transmission Holding Device
Thats a great idea for holding the trans steady on my bench. I may try this idea. Thanks for the suggestion too.
  • Jack Richard
25 May 2015 13:29 #29648 by Jack Richard
Replied by Jack Richard on topic Re: Transmission Holding Device
I have found using 1/2" threaded pipe nipples in the drain holes of the tranny and differential works nicely. Us a close nipple (short) in the differential hole and one about 3-1/2" long in the tranny hole, then screw on 1/2" pipe threaded flanges attached to about 10" long 2x4 blocks. I used an engine hoist to lift tranny onto the workbench, two strong men could do that job too. If you turn the blocks lenghtwise, the tranny can be tipped onto its side, or upside down if needed.
Jack Richard, D.D.S. This email address is being protected from spambots. You need JavaScript enabled to view it.
  • 1748 S
22 May 2015 01:48 #29577 by 1748 S
Transmission Holding Device was created by 1748 S
I was a nice looking trans mounting device that fits into an ordinary engine stand. I liked what I saw and want to build one. Does anyone have the demensions or is it just make what works for you. Thanks all.
