Engine Pulling Time
LOL--in 1955, rust prevention consisted of zinc-chromate primer and a hard enamel paint. I'm not sure Rust-O-leum had been invented yet.
The green color came about because that's what my dad had most of a quart of!
- acdclubadmin
- New Forum User
Tom_Parkinson wrote: See pix of 1509A here: mbcurl.me/YCSE
Other than looking really cool Tom, why did you leave your engine block green?
- william057
I also have found this day to be a Happy Memorable Day. The engine/transmission in 1752A finally been pulled. It put up a fight until the end and as my wife stated there is a foreign language of engine pulling that she had never heard of. After a little bit of negotiating the leaf spring, struggling with the front drive axles, etc., it is resting on wooden blocks in our garage raised floor area for final disassembly with the engine headed to the engine rebuilder west of here and the transmission heading a little south of Grand Rapids for its rebuild. It is one greasy mess (greasiest of all engines I have ever worked on) and I have to comment that even after emptying all the fluids prior to pulling, the transmission just kept pouring out more oil than ever imagined. So, far, the trans axles look really in good shape, transmission gears look good, no metal in the oil, etc. The engine was a known problem with a head gasket seal blown and one piston frozen. Other wise it is not in bad shape.
I am curious what the weight is of both components together, and our them separated. Any ideas or facts, figures on this?
Happy Memorial Day and Happy Memorable Day.
Bill
Bill Heisler - 1936 Cord
I also had a modification done by the late Tom Pendergast to the synchronizer ring to prevent it from malfunctioning and allowing the spring loaded balls to pop out and mangle the gears. I haven't looked, but that too should be in the trans manual and can be done for little cost. .
One more point to note is that once you slide the trans back the 3/8" off the dowel you MUST support the transmission at all times, you can not let it rest on the input shaft. If you do you run the risk of bending the input shaft (I have seen several of these bent). It's much easier to do it on the floor where you can slide the transmission straight back. Also if you think pulling the transmission is by itself may be hard, try putting it back in!
Gary - if your mind is like mine... you are in deep trouble
You'll have to remove the oil pump and shifting assembly from the front of the transmission to remove it. Just take it slow and be sure everything is unhooked. You don't want to damage the lines for the engine temperature or oil pressure.
- Thank you received: 136
Thank you, Jim. You have given me a precious gift: peace of mind.
Get some sleep. if yours is already done and you are only going to do light driving it will be fine. The original thrust washer will last especially if you are careful on the shifts. I think George has been running the original for years in his phaeton. I've pulled apart several transmissions with the original thrust washer still intact (working on one now).
But they do fail, So while someone is rebuilding a transmission it's worth while to upgrade and remove a known problem. I figure I never know how the car will be driven in the future. Most start off as trailer queens or very light driving. but if they ever get an owner like me, they get driven hard. I'd rather be safe.
Also to answer your question you can not do this modification without removing the transmission and disassembling the entire upper shaft.
CORDially,
I am losing sleep over that thrust washer that I am sure my dad and brother did not upgrade back in 1955. I mean, who knew back then that such an improvement should be made?
1509A's engine and transmission assembly are currently out of the car. Can this shaft be removed and the parts upgraded without separating the transmission from the engine? The other side of the coin is that 1509A will never see more use than parading and local pleasure trips, and presumably that thrust washer can be expected to last through a lifetime or two of such light use.
Decisions, decisions. Any input?
When you get to the engine and transmission pull them out in one piece and separate them on the floor. It's much easier.
Also when rebuilding the transmission send it to someone who has done several of them, it's worth the money to have it done correctly. The transmission is critical to having the Cord run and shift correctly and there are tricks that aren't in the manual. Plus after you have done several you develop the "feel" for how it goes together and what is right. Since you are in Michigan I would send it to Lee or George.
Be sure to obtain the ACD Transmission Manual book from the ACD store. It's the best ten bucks you will spend on this job.
One strongly recommended item to do when rebuilding the tranny is to replace the 3rd gear thrust washer with a thicker hardened steel one. This requires some machining work to be done. Read about it in the Forum or in the Manual.
- william057
