Westchesters with outboard taillights?
- rallyemidland
I was supposed to replace the clutch last week, but we became unusually busy in my shop, and had to delay that project. I am not looking forward to doing that job, anyway.
Dale Martin Midland, Michigan
I recall at the time there was a lot of discussion about how the cars became equipped with the rear spare (ex. dealership installed or ...) and unfortunately records are largely nonexistent at best and photos just as hard to locate.
Here are the photos that Johnmereness posted a while back.
I find this to be fascinating. Were the Continental kits factory-installed, or were the cars ordered to be ready to accept an after-market kit? Or something else?
I was thumbing through Josh Malks' Cord 810/812 The Timeless Classic, and my eyes went to two pictures of a sedan fitted with a Continental kit. (Sorry for the poor quality of the pix; this was the best my scanner could do.)
So......the brain starts to crank.... Maybe the outboard taillights were put on sedans for which a Continental kit was ordered or anticipated?
Dale, is there any evidence that your Cord ever had the hardware shown in the pictures?
Cords = Curiouser without limit.
- Mike Dube
Frank&JJ wrote: Dale, I've had the pleasure to pick both a Cord 812 and a Citroen TA apart, and to me it's quite clear that the Cord 812 design is quite strongley based on the Citroen. Monoqocue construction,in the way the floor and frame is braced, doors are built... Suspension and engine construction are different, gearbox placement about the same.... (No intention to offend anyone!)
Frank
Stands to reason as each admired the other's work.
8-100A
Frank
I haven't been on in a couple of days and lots of great info. I would just like to add my 2 cents on a couple of points.
The brake booster was a common addition back in the '70's and '80's. There are a couple of write-ups on how to do it. The best place to hide it is in the tail section of the left front fender. You can easily mount it on the rear fender support and it will never been seen.
I will say this on the Lockheed brakes, I had them on my '36 sedan and never had any trouble stopping. If they are set up correctly, have the proper linings on them they will stop just as well as the Bendix brakes (37).
A comment on owning two Cords - if you think one Cord is a problem...two Cords is 4 times the problems. I have found that either they both run well (which is very seldom) or they both have problems. I's swear it was "sympathy pains"
CORDially,
- rallyemidland
Dale
- rallyemidland
Josh Malks' comment on some Cords having outboard taillights suggested that they were only that way on a small number of 1937's. Your car is numbered as an 810, ie, a 1936.
Do you know which brake system your car has? Bendix brakes--1937 production--have a star wheel adjustment at the bottom and tend to actually stop the car. Lockheed/Wagner brakes (1936 production) have two adjusting cams (at 10:00 and 2:00), no star wheels, and stop the car as a matter of good luck.
Your car is a matter of historical interest to me since it is the only Westchester I have seen with the taillights in the body. I wonder how many were made, and when.
Cords: Curiouser and curiouser and curiouser and then even more curiouser!
- Thank you received: 136
- rallyemidland
I would love To have two of these cars. One, a nice driver like this and a completely orginal , totally accurate to the original build. That would be nice.. Right?
Dale
What a joy to have your information on this car! I'll be very interested to hear what you find inside the trunk lid since I can find no images of another Westchester that has the outboard taillights.
Since your car is an 810, presumably it has Lockheed/Wagner brakes. That in itself is plenty of justification for a vacuum booster!
She is a beautiful car, and it sounds like the changes are functional improvements (of which I approve, not being a purist!) For sure, when 1509A eventually hits the road, it will have improvements also.
Thank you for your post!
- rallyemidland
The shift control ball valves were difficult to adjust, and I bought the drilled and taped elbows at Auburn. They work well, and the ball valves are gone.
I have been cleaning up wiring and I stealthed in a Pertronix ignition.
I installed a vacuum brake booster (sorry purists...). It sure makes me a lot more confident at 70 miles per hour. At least it is mounted low on the right hand side and is not easy to see.
This week she is getting a new clutch and a set of 4 new (1970s) wheels, then going to the body shop to get the wrong mirrors removed and to fix a couple of blemishes in the paint.
I would love to find an original heater, but the one in it works very well and looks decent. Any ideas???
Dale Martin
I believe you're right. I zoomed up the image to 600% and it's evident that the wires are there, parallel to each other, and then sent off at a right angle to the driver's side.
Good eyes, Jim!
Since you mention it, I HAVE seen the brass elbow fittings with the drilled, tapped, and inserted bolt to restrict vacuum. In fact, in my treasure trove of 1000's of downloads regarding re-assembling my Cord, I found a picture of them. I think these were on EBay. I had forgotten that I had the images. I wonder what additional tidbits that I thought were a good idea I have forgotten also!
These adaptations look easy to perform, but I DO like the ball valve option. I'll decide when it's time to make the decision: Lowe's is 3 minutes away, and they have the ball valves available.
Cords: Curiouser and curiouser and even MORE curiouser!
Also I think the horns are correct. Remember there were three different horns used thru the production run.
Since this car has apparently been converted to 12-volt, I wonder if there is a bank of modern relays that are functioning in lieu of the original relays. I considered doing this myself, but with sealed 6-volt relays. If so, they are not shown in any pix that I have seen.
I like the ball valve idea for the vacuum lines--I think 1509A will have that added feature when I reassemble it this spring and summer.
This is said to reduce clunks while shifting, something I have yet to try.
Was also puzzled by the missing wiring on the solenoids.
- Pat Leahy
- Thank you received: 28
Pat Leahy
The finally I see an interesting place to collect enough exhaust heat to make the auto choke function. See it off the drivers side exhaust pipe just inboard of the fence. Might very well be converted to 12 volts too. Still a very nice looking cord.
Interesting info. If this car is in fact a 36, and not the 36 serial number plate attached by someone to a 37, then the mystery of the location of the taillights is even more engaging.
Here are more pix of this car. It appears to have been converted to 12-volt with an alternator and what looks like a ceramic ignition resistor on the right firewall. It has modern driving lights and turn signals on the front. There's what might be a coolant overflow canister in front of the radiator.
Members--any more info ?????????????????????????????????????????????
- Tim Gilmartin
- Thank you received: 57
I have been interested in these photographs for some time. They are images of a nicely restored Westchester sedan (stated to be an 810 1937 Cord 810 Westchester, s/n 2593A, engine no. FB524) that was at one time for sale at Gullwing Motors. The engine is normally-aspirated and the external pipes are add-ons. The car is fitted with seat belts.
Of course, if the serial number in fact states 810, and not 812, the car is a 36, not a 37. In either event, I could find no reference to serial number 2593A in either 810 or 812 listings.
What caught my eye are the taillights. The taillights are not in the trunk lid, but rather are mounted outboard of the trunk, like a trunk-back sedan.
Well, I thought maybe in 1937 Cord started to place the taillights outside of the trunk lid, perhaps using body panels pre-stamped for the trunk-back. So I googled Cord Westchester and looked at pages and pages of Cord photos to see if I could find a similar construction. No luck.
What I DID find is that the Graham Hollywood consistently had its taillights mounted outboard and not in the trunk. I also found an image of a barn-find Hupmobile Skylark whose taillights ARE in the trunk lid.
So, does anyone know what the factory did with the taillight location? Is the Westchester in the attached photos correct? Is this car possibly a Graham Hollywood body that was converted to a Cord? Could it have been a trunk-back that someone cut off the welded-on trunk and converted the body to a slant-back? Does anyone know or own a Westchester with the taillights mounted outside the trunk lid?
I would be happy to own this car, but if I did own, it, I would like to know what it is.
Cords: Curiouser and curiouser!
