1937 Cord Trans Numbers
Cordially Mike
Almost all S/N's were stamped on the top as we are used to seeing. There are some that were stamped on the left side like T508 and T238 above. These are very few, I only remember one in Certification.
I have never seen the stamping on the right side as shown above. That is where I need to do some additional research and try to figure it out. The photos here are very helpful.
- JOEL GIVNER
I thought all S/N's were stamped on top like the first photo T1577.
I don't believe I ever recorded the number on the side
Joel
JEG
- JimArneson
- JimArneson
- JimArneson
First: Transmission case marked T1577 on top and T150 on the side (3 photos).
See all the photos here... jwpictures.smugmug.com/Cars/Engi ... ion-Cases/
[/img]
- Tim Gilmartin
- Thank you received: 57
CORDially, Tim.
Could you either post or send me some photos of the numbers on the cases you are talking about.
Most of the transmission cases were marked on the top as noted in the posts above. There were some early cases that were on the left side. I've never seen or heard of them being stamped on the right side, but then again we are still learning about these cars.
- eaj564
Eric
- Tim Gilmartin
- Thank you received: 136
