- Thank you received: 135
Inner Universal Fun
23 Nov 2014 22:53 #28535
Replied by 1748 S on topic Inner Universal Fun
Jim its the pins that holds the steel shell to the dog bone side of the universal joint. I got it figured out. I was using a sharpened flat blade screw driver but was getting lots of flex. Ended up using an endustrical scraper I made up probably 20 years ago. All the scraper is was a broken power hacksaw blade sharpened on one end. Surprisingly they have a hardened dege where the teeth are but the rest of the blade is softer material. This blade was about 24 inches x 2 inches x 1/8 inch. A couple of 1/4 inch cork gasket material glued to the handle and some electrical tape makes for a nice handle. Leaving the end clear makes for a very positive hit directing thru to the work being done. Thanks for the tip on the roll pins. Thats a good idea. I'm sure these joints have never been apart since they were made some 75+ years back.
23 Nov 2014 22:19 #28534
by
Replied by on topic Inner Universal Fun
What pins are you talking about? The pins that hold the inner and outter CV joints together? If that's the case when you put it back together use a roll pin instead of the drive pins. It holds just fine and a lot easier to get out.
23 Nov 2014 00:24 #28524
Inner Universal Fun was created by 1748 S
<!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: --> Wow is this a ruff job getting the 4 pins out of the covers so I can clean and inspect everything. Seems once I get the pin up about 1/32 I can then use a pair of 12 inch long end nippers to grab the head and rock it out using the leverage. But getting them up that high is no fun. I have one side completely apart and cleaned but I wonder how the grease stays in the joint? Is there a plug under the spring that holds the grease in the joint or what?
