- Thank you received: 135
Piston To Cylinder Clearance
30 Oct 2014 13:48 #28440
Replied by 1748 S on topic Piston To Cylinder Clearance
Thanks Mike for the help. I know the top of the pistons are tapered compared to the actual diameter where you suggested. These pistons are new by the way. I plan to check the other bank.
30 Oct 2014 01:40 #28434
Replied by mikespeed35 on topic Piston To Cylinder Clearance
The piston to cyl. clearance I us is .001 for each inch of bore. .006 is too much clearance in my opinion. Make sure you check then all. I have seen sets of pistons with inconsistent dia. Check the dia. at the bottom of the piston skirt, not up by the rings.
Cordially Mike
Cordially Mike
29 Oct 2014 04:15 #28429
Piston To Cylinder Clearance was created by 1748 S
Well so far I have measured 4 cylinders and they are 3.507. I have not found the 2 thousands taper my Dad told me the cylinders have for wear in them. But thats a good thing. So I measured one piston and its 3.501. So that makes the running piston to cylinder clearance 0.006. I'm no expert but I feel thats perfect. Anyone know what I should have. I also need to know what the running clearance is for the rods and the main bearings. Thanks for all the help. I have been getting some very helpful pm messages too. With this help I will be able to return my engine to even better running condition that when I got it. Thanks everyone. This is a wonderful helpful forum.
