Generator Mounting Bracket
  • E L
22 Aug 2014 00:31 #28015 by E L
Replied by E L on topic Generator Mounting Bracket
GCO 4804A
  • 1748 S
  • Platinum Forum User
21 Aug 2014 23:39 #28013 by 1748 S
Replied by 1748 S on topic Generator Mounting Bracket
Thanks E L. Can you tell me what the Autolite model number was for the 2 brush generator. Thanks.
  • E L
21 Aug 2014 17:53 #28012 by E L
Replied by E L on topic gen bracket
I believe that the 3rd style bracket with the curved bottom was used on 37 std models in late production that had the 2 brush shunt generator.
The reason is that the larger generator would hit the air cleaner. Thats why it was moved to the passenger side of the engine.
  • 1748 S
21 Aug 2014 14:28 #28009 by 1748 S
Thank you for this answer Pat. As I continue my restoration of my 37 Cord I watch this site. The unmolested 37 Cord in the Schlumpf's posting shows the curved bracket. I have seen the supercharged engines u type bracket with the offset bent leggs on it. Thanks so much for this information too.
  • Pat Leahy
21 Aug 2014 14:13 #28008 by Pat Leahy
Replied by Pat Leahy on topic Generator bracket
To my knowledge the factory used (3) different brackets for non-supercharged Cords. The first style was a simple "U" type bracket used on early type generators, the second was a simple "U" bracket for late generator, and last was a bracket with an additional curved bottom plate. I think the last one came on late FB blocks with side mount fuel pumps. I have all three types. All S/C cars had an offset bracket that allows clearance around the supercharger.
Pat Leahy
  • 1748 S
20 Aug 2014 17:39 #27994 by 1748 S
Generator Mounting Bracket was created by 1748 S
Why did the factory use so many different generator mounting brackets for a non supercgarged 810 or 812 engine? Just wondering...
