- Thank you received: 135
Coolant
- Red Brick
Cordially Mike
- landmark
Frank&JJ wrote: Matt, to further confuse matters, here's a "test report"by a competitor.
www.norosion.com/evanstest.htm
As I said before,the one thing worrying me is flammability.
I did a small test and it will burn when heated with a blowtorch.
So spraying evans cooling fluid across your heated exhaust manifold may
not be a good idea.
Frank
Hello Frank,
with such a high flammability, it is maybe not a good idea to use that stuff as a coolant.
I just checked what flash/flame- and boiling-point is labeled for propylene glycol
Boiling point: 185°C (365°F)
Flash (flame) point: 104°C (219°F) <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: --> <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: --> <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: --> <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: -->
Cheers
Matt
Was man besonders gerne tut,
ist selten ganz besonders gut
Wilhelm Busch
not be a good idea.
Frank
- landmark
Frank&JJ wrote: Mike,
Evans claims a -40 F freezing point for it's NPG+ coolant and a -79 F freezing point for it's NPG coolant.
Frank
Hello,
if I get it right, Evans NPG coolant based on propylene glycol, that kind of Coolan liquids are used aswell for the heat-transport in solarthermics collector systems.
It seems to me that the main difference between these two products is the price. Here in Germany the solarthermics liquid costs (approx.) less than one third (1/3) of the Evans NPG coolant...
Cheers
Matt
Wilhelm Busch
Frank
Looking at the numbers on the Evans website and elsewhere had me worried a bit about lower heat transfer and wear on the waterpump due to higher viscosity, but all seems to work properly.
The one thing that does worry me is the flammability.
Frank
- Red Brick
It's good to know that the waterless coolant seems to have been effective in the Bentley, but how did you decide it was safe to use?
No problems so far.
Coolant temperature is a bit lower, something I didn't expect.
No more loss of coolant after shutdown when hot.
We'll be running it in the Bentley this year and if all continues to go well
do the Cord next year.
Frank
- Red Brick
I saw two videos from Jay Leno's Garage (the newer video is at ; the older video is at ).
The Leno videos seem to be sponsored commercials for the manufacturer, but they do state that the waterless coolant is better for aluminum engine parts than water or a water/glycol mixture. In addition to being a "lifetime" coolant, the fact that there is no water in it would be easier on the water pump.
Leno stated that water in the cooling system caused problems in his Duesenberg in the past, but since using the waterless coolant, he has not had a recurrence of the problem. If this is true, then would it be reasonable to use the waterless coolant in a Cord engine?
