Transmission serial numbers
  • Visitor
  • Guest
27 Feb 2014 02:09 #27124 by
Replied by on topic Transmission serial numbers
Tim,
Some of the very early transmissions had the numbers stamped on the side of the trans. look on the side below where you would expect to see the number and about the middle of the gearbox (i.e. a little in front of the oil fill plug). Let me know if you find anything.
  • Tim Gilmartin
  • ACD Club Past President
26 Feb 2014 22:56 #27123 by Tim Gilmartin
Transmission serial numbers was created by Tim Gilmartin
Hello all : I mistakenly put this on the Auburn forum.
I'm helping new Club member Les Gerber disassemble his 37 S/C Beverly. No serial numbers were found stamped on the transmission case. Yes, the cover is off. Has anyone else found a tranny with no stamped serial numbers?
Tim.
