810-812 headlight bulbs
23 Oct 2013 12:04 #26167
Replied by Curt Schulze on topic Bulb
The line up disc is soldered in place. Heat it up and turn it to the desired location. It will not hurt the bulb a bit
23 Oct 2013 07:24 #26163
by
Replied by on topic 810-812 headlight bulbs
- stroker
17 Oct 2013 00:50 #26111
by stroker
810-812 headlight bulbs was created by stroker
Gents- I have headlight reflectors which I think are correct and fit my car nicely, have the parking lamp hole on the bottom of the reflector and three sprung posts around the main center hole. I have several bulb types with corresponding holes in a base flange. My problem is when the bulbs are inserted and turned in place the high/low filaments are horizontal, creating wall images side by side.
What is the correct bulb that when inserted the filaments are aligned vertically?
This is driving me nuts and I hope someone can help!
Pete Rhoads
Pete Rhoads
