- Thank you received: 35
Bendix brakes
- George van Nostrand
18 Feb 2013 16:44 #24533
by George van Nostrand
Replied by George van Nostrand on topic Bendix brakes
Tom; The sixth spring you mentioned holds the brake shoe against an
eccentric located bhind the web of brake shoe.
George.
George.
- T_Hussey
18 Feb 2013 13:48 #24530
by T_Hussey
Cheers,
Tom Hussey
Bendix brakes was created by T_Hussey
Hi,
The Bendix brake design uses six springs on each wheel. There are two return springs, two hold down, one for the adjuster... What is the function of the sixth spring? It looks to be some sort of auxiliary return for the leading shoe, pulling from the shoe to some sort of bracket on the backing plate.
Cheers,
Tom Hussey
