Richardson Front Hub
- Scotty
22 Jul 2012 02:20 #23185
by Scotty
Replied by Scotty on topic Richardson Front Hub
Hey Tom,
Thanx for the reply, I have been in touch with Bill Richardson. I finally got the hub out of the housing. I lost the outside bearing, which ruined the sleeve but little else. The bearing race was on the hub pretty hard, but we got it of on a lathe. The housing is salvagable, as is the hub. With some bearings, seals, and a little machine work I should be back on the road soon.
Scotty
Scotty
21 Jul 2012 06:28 #23180
by Tom Georgeson
Replied by Tom Georgeson on topic u-joint
I would contact Bill Richardson in AZ and ask him what to do.
- Scotty
06 Jul 2012 06:14 #23143
by Scotty
Richardson Front Hub was created by Scotty
The wheel bearing retainer nut behind the hub backed out completely (pretty sporty at 60 MPH). I have the axle out of the car and the CV joint housing on the bench. The hub is still in the CV joint housing along with the bearings. I can see the wheel bearings from inside the housing, and the bearings appear to still have considerable grease and do not appear to have overheated.
My question: How do you remove the hub from the housing? I don't want to cause any more damage removing the hub. Any help and suggestions are appreciated.
Thanx in advance.
Scotty Davis
Thanx in advance.
Scotty Davis
