chassis no.
- oldbanger71
Richardson CV- joint conversion long bolt hub, drums can be taken off without disturbing bearings and no risk to brake the flanges, no noise in corners.
Don Wohlwend's rear hub long bolt, so you can take off the drums without disturbing the bearings and they don't crack and last but not least, new one-pieces-aluminium Rims from Don as well, they look the part, close to the original, no crackrisk and you can use radial tubeless tyres if you want or with tubes if you like.
Henry Portz electrical stuff like the uncutt wireingharness, and new Waterpump impeller-kit. Henry gives you Gearbox-advise; get your oilpump overhouled.
On the list would be also the new redesigned cylinderheads if my originals don't work. The new microswitch for the gearbox and new speedleaverswitch ist good money worth to invest. Just my 2 cents,
Read the articles of Don Wohlwend in the newsletter : Number 3 2008 , Number 6 in 2008 and number 7, 2008 . Best is to buy the Newsletter-CD where you can find all artikles back to the 50's. Cordially Philipp
812 310 121 S
- johnoliver
The car has been sold to Isac van der Wat. It was in storage since the death, some 11 years ago, of John Saunders. The following information was supplied with the car: serial no 810 , 1154 S engine no. FB269 and body no. C90 210 Beverly sedan fastback. This confirms exactly the data that you were able to look up for me. There is as yet no sign of the data plate that was on the car and it must have been removed at some time when the car was repainted. It may still turn up in the effects of the late owner.
Isac tells me that he has known of the car for at least the last 20 years and that he probably saw this car originally some plus minus 40 years ago when it was still complete and a runner.
The car is in need of a ground up restoration and although striped it is mostly original and not previously worked on. Work is to start on the car as soon as possible and advice on the gearbox restoration and CV joints will be required.
John Oliver
- oldbanger71
812 310 121 S
- oldbanger71
I did some research with some well known ACD Members aubout what Car and Parts-pile i have.
Physically i have : Car body of a 812 Custom Beverly 8 Louvers with front/Rear folding armrest's, belived to be serial number 812 310121 s going by Ron Irwin's list.
i have Engine FB 1811 non Sc but, with Exhaust of a SC. some additional SC-part's are there as well. The original engine should be FC2625 which appears to be lost. The stub frame is stamped as 1482 but, according you, might also be unitnumber 2482 A . Engine Number FB1811 is clearly linked witch Charles C. Audet and D.J. Hellman and also the title is connetcted to FB 1811 / Audet/ Hellman, obviously last registered in 1974 ( with engine FB1811, i belive ). In Ron's Master list FB 1811 figurates as Replacement engine in 812 312121 s. In connection on the FB 1811 california titel is first David Johan Hellman, and second ; Carswell Charles Audet . The Car had then registration KAX514,Both of this registrations plateswas where stolen during the transport between USA and Switzerland, when i bought it ! According this well known ACD- Member the bodynumber could likley be C105 171 which would fit to 310121 s. The body was hacked for rearwheel drive, probably after 1974 and apparentley rhumors say that once there was a big Caddilac engine in. If my stubframe was realy (1)482 A , according you, it might have ben aquired in '87 , by who ? Was it the seller, that sold it to me trough Hyman , that tried to undue that Hot Rod caddilac thing ?. What else can you tell me about 2482 A and (1)482 A ? was it originally 482 and someone stamped a " 1 " in front... it doesn't look like. Interesting is, that i received the car with a Westchester-Steering collumn, which was to short for Custom Beverly . I wrote to C. C. Audet but he was not much of help.
The twisted ID of 310121 S and stubframe 1482 / 2482 A, is why i talked of donor car stubframe. Here are the numbers i have and im curious if you find new or other links to mach up. if you like i can send you the letters, of that well known ACD member, that kindly helped me to sort this out . It's not yet restored and it will be interesting to get the ID correct since the car was sold with a made up VIN which is 812 310 482 s, by Hyman. Unfortunatly i had it imported with this number and registered at the swiss Import departement and only found out later about 310121 s. Unfortunatly Hyman refused to name me the previous owner, that sold it to him! And when i kept asking him, he obviously gave me a made up name to get me quiet. Please send me a PM with your direct e-mail-address, as the letters are long and large in size. CORDially Philipp
812 310 121 S
- Tim Gilmartin
- Thank you received: 57
I don't know about the "donor car" you are referring to. Your 1482 frame stamping would mean a serial number of 2482A. Ron irwin's notes show a 2481A and a 2483A! Maybe you have an " unknown" cord, or at least the stub frame for one.
The plot thickens!
Cordially, tim.
- Tim Gilmartin
Unit number of 154 would make serial number 1154 S. (S) for Beverly or Custom Beverly. Engine Number should be FB 269; central manufacturing number (C.M.C.) should be C 90 210. As of 1991, a mr. Saunders in south africa owned this car. Right hand drive, and with arm chair seats with a non-folding center arm rest.
This info is from ron irwin's (the cord historian) notes on all the known cords.
Tim.
- oldbanger71
Thats what mine looks like and if you look close enough you see a "1" that resebles an " L" so mine say's for a unknown reason 1482, the one should not be stamped in front, according to Josh's " Cord Complete " book, This number corresponds with the donor car VIN 810 1482 A.
I recommend you to buy Josh's Book not only for the information but also because it's avery nice book to have.
CORDially Philipp
812 310 121 S
- oldbanger71
Engine should fit to the framenumber and Bodynumber and VIN but are individual numbers ( they correspond normaly with the records ). But will not if either of them have ben replaced at one point.
Please look if you " L " could be a "1" in the same style of the other letters. CORDially Philipp
812 310 121 S
- johnoliver
The number is there just above the line of the two rivets and is so faint that it would sand off very quickly.
Ok so the number is L 5 4 large and well spaced.
The engine is not in the car but lying on the floor unfortunately on the side where the number should be, as soon as I get some help to move the engine I will list its no. also.
The cowl shows clearly where the original tags were meant to be and it still has the rivet holes and a slight indentation where the tags once were. But this is definitely on the right hand side.
The car is a right hand drive car.
Thanks, John Oliver.
- oldbanger71
Tim is right in respect of where to find the chassisnumber BUT...
I would recommend you, not to use Sandpaper to find the numbers, as he menshioned that they are very lightley stamped and could easy be sanded away befor you notice, better use chemical stripper !
Cordialy Philipp
812 310 121 S
- Tim Gilmartin
Tim.
- johnoliver
John Oliver
- Tim Gilmartin
Please advise me if you find the unit number; i may be able to use that number to find other info about the car.
Cordially, tim.
- johnoliver
I am interested in purchasing a Cord 810 Beverly sedan that is forsale. The car has had the makers info plate removed from the outside right cowl.
Where can I find a chassis no?
