Automatic choke
- T_Hussey
21 Jan 2012 02:57 #21970
by T_Hussey
Cheers,
Tom Hussey
Replied by T_Hussey on topic Automatic choke
Hi Charles,
I am not sure if your car is supercharged or not. I have data for both AA-25 and EE-15 if it will help you.
You probably do need a choke of some sort to richen the mixture when the engine is cold. I can be workable without but often more cranking is needed, pumping the accelerator to richen the mix also. This is not the best.
The auto choke is built into a small housing at beside the top housing. The choke shaft runs into it. No parts are easy to get, but this might not be too bad. The housing looks to be the same on any number of Stromberg carbs in the 40s.
Cheers,
Tom Hussey
Cheers,
Tom Hussey
Cheers,
Tom Hussey
- charlesflick
15 Dec 2011 02:25 #21632
by charlesflick
Charles Flick
Automatic choke was created by charlesflick
My car does not have the Automatic choke. Are they available? Do I need it if I am not having it judged?
Charles Flick
