Checking trans level
- ETHAN ALLEN TURNER
Was the article and/or instructions ever printed in the Newsletter? If so, it should be on the Disk.
- Justin Kerns
- Thank you received: 8
If there is a box somewhere at our office or elsewhere I'd love to know about it.
Justin
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
Better yet buy the manual, last I checked there were still quite a few left in the Club's inventory. There is a lot of good information in the booklet beside the information on rebuilding a trans. It's also a great resource to keep in the car just in case.
Mike - the last time I checked the club still had a lot of the transmission manuals left. If and when it comes time to reprint the book there are a few small errors in it that need to be corrected.
- Al Light
Al Light
I do not know if either the club or the ACD Automobile Museum has reprinted these. Excellent guide to rebuilding the Cord transmission.
- Al Light
Al Light
- Red Fred
On another note, I am happy to say that I found the source of my horrible oil leak which we experienced on our first "long" distance, Club drive. Seems my clutch linkage was violating my after-market, spin-on oil filter! It wore a slight crack in the filter.
I have since ground down the offending linkage, and replaced the filter. We went even further the next trip, and all is well.................well, in that department anyway.
Thanks again, RF.
Life Member
So you gotta check your own stick and your own tranny.
Now drop the engine oil dipstick. wiped clean, into the transmission fill hole. This takes a little practice. If it hangs up on the shift rails and you have to push it in, it is not in the right position. It should drop cleanly and completely. Check the lube level on the dipstick, and make a punch mark or scribe to mark the level. That's what you check with in the future.
- cstebbins
This certifies that this Cord automobile has been driven 110.8 miles per hour before delivery - Ab Jenkins
- Red Fred
But I have a feeling that my dip stick is different than most, as I have the aluminum oil pan. So I'm wondering if this is still the same method. Perhaps I should be asking what the length of a regular, steel oil-panned dip stick is from the flange to the tip?
Thanks, RF.
Life Member
- Red Fred
I have an aluminum oil pan, and hence a different engine oil dipstick than usual, so am looking for a quick method of trans oil checking. My combination may not be correct for this method of checking. I can visually see the trans oil level with a flash light, though the filler. Should it be up to the bottom of the side plug (level plug?). I'm smelling gear oil on some extreme up-hill accelerations, and don't want to be over filled, although I imagine that is much better than being underfilled!
Many Thanks, RF.
Life Member
