Oil-pan Drain Plug question
- Red Brick
08 Oct 2014 23:40 #28303
by Red Brick
Replied by Red Brick on topic Oil Pan Drain Plug
Yes - but if you do purchase one, please be sure to tell us which size you bought.
Albert
Albert
- Thank you received: 135
08 Oct 2014 20:03 #28301
Replied by 1748 S on topic Oil-pan Drain Plug question
Nice picture showing how the plug fits. For me I probably will install the fulmoto drin valve because it wont hang down much more than this oem plug.
- RubyDS
- Thank you received: 10
08 Oct 2014 17:54 #28299
by RubyDS
Replied by RubyDS on topic Oil-pan Drain Plug question
- Red Brick
06 Oct 2014 06:03 #28286
by Red Brick
Replied by Red Brick on topic Oil Pan Drain Plug Question
Does anyone have the measurement for a Cord 810 / 812's oil drain plug? If not, I'll try to remember to measure it at the next oil change.
Albert
Albert
04 Sep 2007 17:35 #7928
by Josh Malks
Replied by Josh Malks on topic Oil-pan Drain Plug question
Been in place for over twenty years. No lengthening adapter needed. Just check thread size of Cord drain plug.
- Bill McLaughlin
23 Aug 2007 21:06 #7842
by Bill McLaughlin
Replied by Bill McLaughlin on topic Oil-pan Drain Plug question
Thanks Josh.
Do you remember what size Quickoildrain Valve you bought and did you use a lengthing adaptor ?
Bill McLaughlin
Bill McLaughlin
21 Aug 2007 13:50 #7800
by Josh Malks
Thanks, Balin'. Was a surprise to me!
No clearance problems in many years of using the valve on a Cord 810.
- Thank you received: 19
21 Aug 2007 12:55 #7799
by balinwire
Replied by balinwire on topic Oil dump valve
The quick-change fitting is a nice idea. The detent key is very similar to the Cord column shift reverse detent, pull and push, patent infringement?
I would be concerned about impact with collision with objects, debris as the pan sits so low. There web site says to check if there is an impact check the fitting!
Great article I found while checking Pebble Beach on MSN,
autoshow.autos.msn.com/autoshow/ ... id=5193457
The entire world now knows about the Cord through this comprehensive article! Very impressive, Stringsaver #1
21 Aug 2007 09:19 #7796
by Josh Malks
Don't know, but it's happened to two of mine. ('Course, that's over a period of half a century. . . )
The oil comes out nicely, in a rush. I've never gotten the impression that it's "oozing".
21 Aug 2007 03:21 #7794
Replied by mikespeed35 on topic Valve
Thanks for the link Josh. I've seen these before but was concerned with how much oil is left in the pan and the small drain hole that won't allow the oil to drain quickly and flush out oil better. I know if you change it often enough like we do it's not as critical but still..... I have changed a lot of oil for a lot of years and never had a female fitting loosen. Is this just a problem with 810/812?
20 Aug 2007 13:49 #7783
by Josh Malks
The "round disk" is the visible part of the threaded seat that is swaged into the oil pan. It is twisted both ways as you remove and replace the oil pan drain plug. Eventually it loosens and leaks. The only way to stop it from leaking is to remove the pan and weld the seat in place.
If your plug seat isn't leaking yet, you can prevent this by installing a Fumoto drain valve. I've had one on my Cord for decades. I change the oil by sliding the drain pan under the car and leaning over from the top and opening the valve. No getting under the car. (Good thing too, since I change my oil every 500 miles.) And it's virtually invisible.
See www.quickoildrainvalve.com/
- Bill McLaughlin
20 Aug 2007 13:39 #7782
by Bill McLaughlin
Oil-pan Drain Plug question was created by Bill McLaughlin
My oil-pan drain plug is inserted into a round disc in the oil-pan that started to spin when I tried to remove the plug. I held the round disc with vice gips and removed the plug to change the oil.
However, now the oil is leaking from between this round disc and the oil-pan.
Can this round disc be tightened or gasketed in any way or do I have to take the oil-pan off and weld the disc in place (peresumably inside the oil-pan) ?
Bill McLaughlin
1937 Cord 812
Bill McLaughlin
1937 Cord 812
