- Thank you received: 35
Bohnalite cylinder heads
- George van Nostrand
17 Nov 2022 00:34 #46421
by George van Nostrand
Replied by George van Nostrand on topic Bohnalite cylinder heads
Thomas; The increased coolant capacity of the heads is one of several things you can do to lower engine temperature. Others are; Low temperature thermostats 160 F Closing off the intake manifold, radiator shroud, fan spacer 3/8 ",a Henry Portz modified water pump impeller, The use of water for coolant ( where anti freeze is not required.)
- Emporator
16 Nov 2022 21:58 #46420
by Emporator
Replied by Emporator on topic Bohnalite cylinder heads
Hello George,
Thanks kindly for the information. How have you found the heads performance wise? The increased height is surely a step in the right direction.
16 Nov 2022 15:04 #46419
The C heads were considered to be the first with increased height , made by Eric Cain of Tulsa OK in 1970. See NL August 1970 P14 for details. These were later sold by A-C parts Co.
I have a pair of these heads on my engine.
16 Nov 2022 14:59 #46418
Replied by Curt Schulze on topic Bohnalite cylinder heads
Why don't you go forward and get some heads cast and machined . Maybe you can get it done cheaper?
- Emporator
16 Nov 2022 06:52 #46417
by Emporator
$5000 for a set of cylinder heads is outrageous!
Can anyone tell me much on the cylinder heads with the small letter c in them?
- Thank you received: 219
12 Nov 2022 15:10 #46405
Replied by JIM.OBRIEN on topic Bohnalite cylinder heads
The Bohnalite were very early heads. They are basically the same as the original heads as far as design and serviceability. If you need a set of heads call George A. He has new reproduction heads. I think the cost is about $3000 or $3500 per set (I haven't bought a set in a while so I'm not sure on the price). His heads are excallent.
If you are looking for a set of bohnalite or original heads I'm sure I have a decent set I can sell you for a lot less then $5000. PM me.
- rg171352
12 Nov 2022 03:40 #46395
by rg171352
Bohnalite cylinder heads was created by rg171352
Most of the cylinder heads I have seen for sale are either marked only with a raised G or with the G and a stamped patent number. What was different about the Bohnalite cast heads? Were they better or worse in anyway? The only set I can find online are these:
daytonautoandmemorabilia.org/portfolio_page/cord-cylinder-head/
. The $5,000 asking price seems steep, so it made me wonder what may be special about them.
Thank you for your help.
