- Thank you received: 35
Speedometer jumping question
- George van Nostrand
09 Oct 2022 23:59 #46149
by George van Nostrand
Replied by George van Nostrand on topic Speedometer jumping question
Aris When you lubricate the lower 2/3 rd it takes some lube all the way to the bottom, leaving some the entire length . You don't want too much lube at the top end which may get into the speedo head. Worth a try.
The following user(s) said Thank You: Aris Loumidis
- Aris Loumidis
09 Oct 2022 07:37 #46145
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Speedometer jumping question
Thanks guys!
George you might be so right, I have not lubricated the lower part of the outer cable, just the cable when inserting it from the top which has been done many times so far, so I will certainly try this. How did you lubricate the lower end? Maybe with a lubricated cable length from that end?
Mike I have tried with a short cable and a hand drill the speedometer that seems to work okay so as you say, I'm afraid the outer cable is the culprit, in which case the big problem is routing it in place, especially where it enters the floor of the cabin where my excellent carpet and the firewall carton have to be removed....
Aris Loumidis
Athens, Greece
ACD Life Member
______________
09 Oct 2022 04:54 #46143
Replied by mikespeed35 on topic Speedometer jumping question
I had this same problem with a 1935 Auburn. After replacing the inner cable, sending the speedo to a shop several times with the same results, I finally replaced the outer cable housing and it stopped. There was a problem in the housing that couldn't be seen.
The following user(s) said Thank You: 1748 S, ShanghaiJack
06 Oct 2022 20:27 #46128
Aris ; Did you lubricate the new cable with special grease ? It is applied to the lower 2/3 of the cable.
- Aris Loumidis
05 Oct 2022 09:30 #46121
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Speedometer jumping question was created by Aris Loumidis
Here I am again!
My speedometer needle is jumping wildly between between 20 to 40mph, but runs steady before and after that range. The insert with the gear on it at the tranny end is ok, so I replaced the inner cable but with no success. I wonder if the problem is within the speedometer itself and I plan to open it up as I did decades ago when I repainted the etched numbers on the flat class plate. I read some speedometers have a built-in lubricating hole with felt fabric for oiling the shaft. I wonder if our speedometers have this option, otherwise I'll have to completely take it apart.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
