- Thank you received: 34
Build Date
- john mccall
18 Dec 2021 03:04 #44491
by john mccall
Replied by john mccall on topic Build Date
Gary, the engineering changes are as recorded. They never changed after production was shut down.
You are lucky because your serial number is mentioned twice. On page 29 it is in with a group of cars that had the 43:10 axle ratio and the dates mentioned were from 1/8/37 to 1/16/37. From that you can telll that you car was built between those 2 dates. On page 31 your serial no. is mentioned again with respect to an adapter or spacer under the carb. In that case yours is the only number mentioned and the date to the left applies to the change and BINGO is the date your car was built
- Online
- Thank you received: 304
17 Dec 2021 19:49 - 17 Dec 2021 19:52 #44490
Replied by Terry Cockerell on topic Build Date
Gary this sheet shows the production figures with Cords listed above Auburns for each month.
The page comes from the August ACD Club Newsletter 1967
This may give you an idea when it came off the line.
Last edit: 17 Dec 2021 19:52 by Terry Cockerell. Reason: Adding picture
17 Dec 2021 17:48 #44488
Replied by 1748 S on topic Build Date
These are my original plates and this is the first time they have been published anywhere. BTW does anyone know of this original engine block for my car?
17 Dec 2021 05:44 #44484
My serial number is 1748 S. Tomorrow I can get my Central Manufacturing numbers.
- John Meredith
- Thank you received: 18
17 Dec 2021 05:29 #44483
by John Meredith
Replied by John Meredith on topic Build Date
What can you tell in reference to the build date of 10039B? I assume the B stands for Berline.
Cheers,
John Meredith
Cheers,
John Meredith
- Jonathan Richards
- Thank you received: 24
17 Dec 2021 04:12 #44482
by Jonathan Richards
Replied by Jonathan Richards on topic Build Date
Gary , What is the Serial/Chassis # of your CORD??
17 Dec 2021 02:39 #44481
Build Date was created by 1748 S
I have been looking thru the engineering changes in hopes of determining my 37 Beverly built date. Have I found my Cord was built on January 11, 1937? What are your thoughts on these two dates I found. This engineering changes booklet is very old and came from a passed on member that lived in Kalispel Montana.
