- Thank you received: 304
Laser Welding Worn Brake Drums
02 Feb 2022 05:52 #44789
Replied by Terry Cockerell on topic Laser Welding Worn Brake Drums
Hi Graham, the question was more for Thomas O'Brien's drums than mine.
I have been advised by others in the US that metal spraying is illegal.
In the interium Thomas has found some suitable drums.
His wheels are another major project as they all require new solid centres to be fitted and welded as well as other repairs.
Terry
Terry
- Blackiron
02 Feb 2022 01:50 #44785
by Blackiron
Replied by Blackiron on topic Laser Welding Worn Brake Drums
Terry, have you considered pre machining, metal spraying, then internal grinding the drums ?
01 Feb 2022 23:29 #44782
Replied by johnmereness on topic Laser Welding Worn Brake Drums
Perhaps try to find used prior to spending 1K each
10 Jan 2022 02:18 #44638
Jim I sent you a normal email.
06 Jan 2022 20:36 #44634
Replied by JIM.OBRIEN on topic Laser Welding Worn Brake Drums
Hi Terry, What drums do you need? Front or rear?
06 Jan 2022 10:37 #44630
I received a quote for around $1,000 per drum.
Plan B is being discussed.
06 Jan 2022 04:35 #44627
29 Nov 2021 10:02 #44357
Laser Welding Worn Brake Drums was created by Terry Cockerell
Has anybody had any experience with laser welding worn brake drums to build them up for re-machining?
A company here in Australia seems to have some experience with repairing various types of brake drums.
Just need some background information.
The following user(s) said Thank You: laserchina
