New Transmission Manual errors
26 Nov 2021 14:32 #44329
Replied by JIM.OBRIEN on topic New Transmission Manual errors
If anyone else has any other errors or corrections please let me know ASAP as we are getting ready for a second printing.
21 Nov 2021 22:09 #44312
In looking over the updated Transmission Manual the table of contents and the other pages in the front were somehow left out. I have attached them here for anyone who has the updated manual.
21 Nov 2021 22:05 #44311
Hi George,
You are correct on the bearing numbers. We have been working on updating the bearing numbers, as many of them are outdated. we are also trying to put together a list of th numbers for the seals. Unfortunatly it was not ready for the updated Transmission Manual. We hope to get this out soon.
To clairify your comment on the solenoid lines. The atmosphere and intake manifold lines are reversed. The line to the intake manifold should come off the rear side of the solenoids and the atmosphere (to the air cleaner) comes off the front of the solenoid valves.
Thanks very much for pointing these out!
- George van Nostrand
- Thank you received: 35
16 Nov 2021 02:01 - 17 Nov 2021 15:54 #44285
by George van Nostrand
New Transmission Manual errors was created by George van Nostrand
The new transmission manual has some errors. P-46 Appendix G , Bearings, shows Rear wheel inner cone 2738, correct to 2788. Kingpin lower cup shows A-6175,. Correct to A-6157.
P56 & 61 The solenoid lines as printed by Auburn Automobile in 1936 - are incorrect. Should be reversed
It is unfortunate that these errors persist in spite of numerous efforts by members to update the book.
See updates in Newsletter 2017, #3 by Rick Hulett.
Last edit: 17 Nov 2021 15:54 by George van Nostrand. Reason: Adding reference.
