- Thank you received: 305
Front spring survey
The front spring has two long leaves that can be seen in the attached picture. This particular car must have been subjected to some atrocious roads as the cross member supporting the spring had been badly damaged and strengthened in the past.
Both front wheel hubs had broken and had been repaired to keep the wheels turning. Oddly one hub had been welded on both sides while the other had only been welded on one side. This is the Cord that had also been in a Bush Fire .
- Thank you received: 219
I should probably run a special on cracked wheels!
Pete
- Mike Brady
You must have some parts that don't move quickly. I know I do.....like connecting rods or transmission cases. At least the rods don't take up much room.
If you were looking for something to collect I would have had a few suggestions; probably all lighter that springs!
Pete
I have 13 front springs with 2 main leaves and one with three main leaves.
- wynlaidig
- Thank you received: 44
- Thank you received: 136
- Rileypu29
Bill
Bill Kastanis
Pete
- George van Nostrand
- Thank you received: 35
I have no idea as the originality or when it may have been modified. The car had been in continuous use well up into the 1960s.
To me the ride was pretty firm up front. I had linished the leaves, greased them and wrapped the spring in heavy duty industrial plastic tape.
The spring was within specifications supplied by Henry Portz.
I replaced the saddle with a longer one to spread the load under the front crossmember.
- Tim Gilmartin
- Thank you received: 57
My new old spring came from a pile of parts with no known history. It has three long leaves on the bottom. Two of the leaves have nice round holes on each end for the suspension rod. The third leaf has a very rough cut hole for the rods.
Seems as there is no consensus as whether the third spring was added by the factory or by Dallas Winslow. It definitely has brought back the correct ride height.
So., when you have a chance, check to see if you have two or three long leaves at the bottom of your front spring. and respond here. I’d like to get a rough idea about how many threes are out there, and about any comments on factory or non-factory. Thank you!
CORDially, Tim.
