- Thank you received: 305
Fuel Pump
10 Oct 2021 08:42 - 10 Oct 2021 08:45 #44052
Replied by Terry Cockerell on topic Fuel Pump
My Cord has a late 1937 engine fitted with an AC fuel pump.
Above the flange connecting with the engine adapter are the following letters and numbers.
D0 6K5
D0 6K5
Last edit: 10 Oct 2021 08:45 by Terry Cockerell. Reason: Adding picture
- George van Nostrand
- Thank you received: 35
09 Oct 2021 19:56 #44050
by George van Nostrand
Replied by George van Nostrand on topic Fuel Pump
Thierry; Your fuel pump looks like a copy of the original AC pump. # 3340., type D The AC pump was patented, but possibly it expired allowing aftermarket makers to copy it. Don't know if the parts are interchangeable .
Gas line routing on 812's went from pump outlet -along underside the head--up the front-then to the carburetor. This kept the gas line cooler. Credit - Henry Portz.
- Tcheri
08 Oct 2021 08:23 - 08 Oct 2021 08:24 #44037
by Tcheri
Fuel Pump was created by Tcheri
Hello,
does anyone have technical info on the fuel pump ? Documentation, brand / type ? I was unable to find any information sofar... On the pump, I see a MC or CM, and a reference FP-716.
Thierry
Thierry
Last edit: 08 Oct 2021 08:24 by Tcheri.
