RADIATOR CAP RUST
- Aris Loumidis
If any problems uccur, I'll post an update otherwise maybe problem resolved!
Cheers all!
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
- Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Roads2run
Roads2run
You want the good old fashioned green antifreeze and you may want to read up on "oats" regarding antifreeze. I have been buying NAPA 50/50 for pre 1995 cars.
Also, NAPA carries a water pump lubricant that is the old fashioned white milky stuff - no harm in adding water pump lube to the antifreeze.
Keep in mind that there are frw places in the United States that are exempt from the periodic freezing temperatures and it does not take that long to freeze water.
- Thomas Wilcock
- Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Tim Gilmartin
- Thank you received: 57
- Thomas Wilcock
Tom
- Thank you received: 304
There must be an underlying problem to cause the corrosion on the underside of the radiator cap like Aris has experienced. The grease must wash off the cap over time exposing the metal again. The subject of corrosion inhibitors vs anti freeze coolants really opens up a large can of worms.
- Tim Gilmartin
Tim.
- Tim Gilmartin
CORDially, Tim.
The corrosion is severe. I know it can get cold in Athens during winter however you Cord is stored in a garage. How cold does it get in the garage?
Antifreeze coolants as far as I am aware do not provide corrosion protection.
You need to do some more investigation on available engine coolants.
- Aris Loumidis
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Aris Loumidis
Please confirm that the cap in the pic is the original one for us. I have replaced it at least twice but it is only a matter of time before it rusts badly away.
Are there any correct replacements? Or solutions like chroming or else?
Thanks Ahead
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
