Oil plan plug, yet again
- Thank you received: 136
- Thank you received: 305
I had fitted high powered magnets to the solid drain plugs. The plugs had to be predrilled to accept the magnets.
I use Teflon tape on the tapered threads.
How did you enjoy Auburn?
You are among friends who help each other.
Terry
All of the sump bolts are then easy to get to. The sump can then be lowered straight down onto an old cushion or pillow. The only cost will be gaskests and brazing the female thread to the sump if it does move. You could easily make new gaskets with the right material and some wad punches.
Do you have any other enthusiasts in your area who could give you a hand?
Replacing the sump would be better if you had somebody to put a few bolts back in place while you held the sump in place.
- wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
- wcoye
[email protected]
Bill Coye
Westchester 2240A
- wcoye
[email protected]
Bill Coye
Westchester 2240A
- George van Nostrand
- Thank you received: 35
they might have a vacuum oil changer.
- wcoye
Bill Coye
Westchester 2240A
Mike I don't think it is cross threaded as it is a tapered thread and would probably be leaking.
- wcoye
Bill Coye
Westchester 2240A
Boiling water poured on one side of tie rod ends helps to dislodge the tapers. You could try pouring boiling water over the underside of the the female threaded piece in the sump which will cause it to expand slightly while applying torque to the plug at the same time. You could use some plastic tubeing to direct the hot water onto the female thread and keep it away from the plug. The key being the temperature difference between the adjacent parts.
- wcoye
Bill Coye
Westchester 2240A
