oil capacity of Cord 810 crankcase
- Normandie
28 Aug 2021 12:34 #43820
by Normandie
Replied by Normandie on topic oil capacity of Cord 810 crankcase
thank you
- Thank you received: 305
25 Aug 2021 06:19 - 25 Aug 2021 09:11 #43786
Replied by Terry Cockerell on topic oil capacity of Cord 810 crankcase
Checking the effective length of my 810 Cord dip stick from the flange down to the first mark is 6 - 1/4"
I suppose I should check the tube length on the sump too ..... I will follow up on this.
The tube length on the outer "longer side" is approximately 5 - 3/4" long.
Last edit: 25 Aug 2021 09:11 by Terry Cockerell. Reason: Revising text
25 Aug 2021 03:50 #43785
Replied by mikespeed35 on topic oil capacity of Cord 810 crankcase
Before you do that, is it the correct dip stick? Have you compared it to several other Cord dip sticks?
- Normandie
25 Aug 2021 01:44 #43783
by Normandie
Thank you. I agree.
- wcoye
25 Aug 2021 01:06 #43782
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
Replied by wcoye on topic oil capacity of Cord 810 crankcase
Hi, the Cord Service Manual says seven quarts but I'd keep an eye on the dip stick
Bill Coye
Westchester 2240A
The following user(s) said Thank You: Normandie
- Normandie
23 Aug 2021 17:42 #43772
by Normandie
oil capacity of Cord 810 crankcase was created by Normandie
This may appear to be an elementary question, but here goes. According to the Cord owner's manual the oil capacity in the Cord 810 crankcase is eight quarts. I've had ACD Cord owners tell me that correct capacity is seven quarts. I've also been told that the crankcase should be filled until it reads "full" on the dipstick, which may not be eight quarts.
I would like to hear what others think. I drive my Cord regularly so I want to be sure the the crankcase and transmission are properly filled. Thanks.
