Window Regulators
23 Aug 2021 17:51 #43773
by pete kelly
Replied by pete kelly on topic Window Regulators
Hi Rick
I looked and have 2 regulators but both are different from the 1 you are looking for and do not have interchangeable parts with yours. It might be easier and for sure quicker to make 1 by hand using a hacksaw, a file and a drill.
You might ask ACD Co in Broken Arrow OK an they had some but don't know for what models of Auburn or Cord.
Good luck
Pete
Good luck
Pete
- Thank you received: 305
23 Aug 2021 11:29 #43770
Replied by Terry Cockerell on topic Window Regulators
Guys here in Australia have had good results with high pressure water jet cutting things like clutch plates for vintage motorcycles. Small sheet metal gears should not be a problem. The jet follows a programmed drawing.
- rickvb
23 Aug 2021 09:39 #43769
by rickvb
Replied by rickvb on topic Window Regulators
Hi Again
Have removed the regulator from my 1931 8 98 A Phaeton and pic is attached along with a close up of the problem cog where I think the slip has been happening .
Fortunately I can turn the cog over and play with the alignment and probably get by . At worst could get it remade. The tiny primary gear which is operated by the handle spindle is also a bit marginal but should still do the job.
If anyone has a good condition regulator then I would still be keen to obtain one and ship it to NZ where I live down under .
Rick
Rick
22 Aug 2021 10:11 #43756
But Jim there are a number of parts common to both Auburns and Cords.
Rear spring shackles and door lock striker plates are just two examples that I am aware of.
- rickvb
22 Aug 2021 05:39 #43755
by rickvb
Thank you Pete for super fast reply !!!! I will open up the door tomorrow as it makes sense to either find a regulator or fix the missing teeth as that is what I think is my problem . I am an Auburn newbie down here in NZ and have recently taken over Curt Cutuis' 8 98 and am in the process of fixing little things that will make my compliance journey more straight forward.
regards
RIck
regards
RIck
- Thank you received: 219
22 Aug 2021 01:04 #43754
Replied by JIM.OBRIEN on topic Window Regulators
Rick, Ask over in the Auburn section - the guys over there can help you out. I don't know much about the Auburn parts...but I'm learning fast!
22 Aug 2021 00:58 #43753
by pete kelly
Hi Rick
Can you post a pic of the 1 you want or the 1 for the other side?
Pete
Pete
- rickvb
21 Aug 2021 11:25 #43750
by rickvb
Hi Jim
You wouldn't perhaps know of a drivers door regulator for a 1931 8 98A ????
regards
Rick
regards
Rick
- RKF
20 Aug 2021 13:14 #43746
by RKF
Replied by RKF on topic Window Regulators
Thank form the reply
I won't be in Auburn
Can you tell me the price and I will send a check
My cell is 585-309-2588
Randy
Randy
20 Aug 2021 01:53 #43742
HI RKF, I think I have them, I'll check tomorrow. Are you going to be in Auburn in a couple of weeks? If so I can bring them.
- RKF
20 Aug 2021 01:25 #43741
by RKF
Window Regulators was created by RKF
Does anyone have any Window Regulators they will sell?
I need three.
Have one for the right rear
I need three.
