Dual Chamber Master Cylinder
- tom clarke
20 Aug 2021 16:56 #43748
by tom clarke
Replied by tom clarke on topic Dual Chamber Master Cylinder
Thank you so much for the info. Obviously it is a relatively easy job, and should improve my braking safety immensely.
Tom Clarke
Tom Clarke
- Thomas Wilcock
19 Aug 2021 10:28 #43737
by Thomas Wilcock
Replied by Thomas Wilcock on topic Dual Chamber Master Cylinder
Because the master cylinder is lower than the wheel cylinders you will need a residual pressure valve on the front and rear lines to maintain fluid pressure at the wheel cylinders. A 10 lb. one is recommended for drum brakes. Also should have a proportioning valve for the rear line to adjust in order to prevent the rear wheels from locking up before the front.
Tom
Tom
- Thomas Wilcock
19 Aug 2021 10:01 #43736
by Thomas Wilcock
- Thomas Wilcock
19 Aug 2021 09:51 #43735
by Thomas Wilcock
I converted mint to a dual chamber. I used a master cylinder from a 1969 Cougar. I believe Mustang is the same. I made a 3 bolt to 2 bolt adapter that fits on to the original mounting bracket. There is ample clearance to the rear cross member when assembled.
Tom
Tom
- Thank you received: 305
19 Aug 2021 00:22 #43734
Replied by Terry Cockerell on topic Dual Chamber Master Cylinder
ACD Club member Tom Parkinson in Michigan has done this modification.
His contact details are in the Directory.
- tom clarke
18 Aug 2021 21:18 #43733
by tom clarke
Dual Chamber Master Cylinder was created by tom clarke
I'm a fan of dual chamber master cylinders for safety reasons. Has anyone converted their '36/'37 Cord from a single to dual chamber unit. If so, info on what substitute will bolt in easiest would be appreciated.
