- Thank you received: 305
How Big A Battery Do I Need ?
12 Aug 2021 21:15 #43695
Replied by Terry Cockerell on topic How Big A Battery Do I Need ?
Thanks Tim, the good thing about Optima batteries is that they are fairly light compared to the "ingot of lead" I was using.
- Tim Gilmartin
- Thank you received: 57
12 Aug 2021 18:01 #43694
by Tim Gilmartin
Replied by Tim Gilmartin on topic How Big A Battery Do I Need ?
Terry: I’m using the Optima 800. More than enough power. With your rebuilt engine, it may be a little “tight” until the engine has a few hours on it.
Tim.
Tim.
12 Aug 2021 05:15 #43689
Hi Mike.
I have good cables with good grounding points and a rebuilt starter motor.
Looking for information on the Internet I found,
The rule of thumb is 1 CCA per cubic inch engine capacity for petrol engines.
The Cord is 289 cubic inches and has a lower compression ration than modern engines, consequently the 600 CCA should be more than adequate considering the mild climate here.
12 Aug 2021 04:01 #43688
Replied by mikespeed35 on topic How Big A Battery Do I Need ?
I have a 950CCA in my Marmon 16, 490 cu. in. Don't think you would need anything that big for a Cord. That presumes you have good grounds, big cables, good starter, etc,etc,etc.
12 Aug 2021 01:11 #43686
How Big A Battery Do I Need ? was created by Terry Cockerell
I'm on the verge of buying a new 6volt battery for my 810 Cord.
In the past I had used a heavy duty battery that gave 900 CCA
I believe 6 volt Optima batteries give 800 CCA
I have another option with a conventional 6 Volt battery that gives over 600 CCA
My question is how much CCA do I really need?
