- Thank you received: 219
Seal
14 Aug 2021 01:30 #43701
Replied by JIM.OBRIEN on topic Seal
Using a Speedi-Sleeve is much easier and cheaper.
- Thank you received: 19
13 Aug 2021 02:49 #43696
by balinwire
Replied by balinwire on topic Seal
i mentioned how my front spindle had a wear channel front the seal riding on it. These are a part worthy of repair and I thought I would share this video of a very similar shaped part that was being repaired and it is a method that work with the Cord front drive steering spindle. Its an interesting watch, my only concern would it draw the temper from the part, this is explained late in the video and it is not a problem.
- RKF
11 Aug 2021 13:12 #43683
by RKF
Replied by RKF on topic Seal
Thank you guys
11 Aug 2021 04:07 #43681
Replied by mikespeed35 on topic Seal
Chicago Rawhide or CR is a name. You probably won't be getting a rawhide seal. The Co. was in business back when rawhide was the material in their seals.
11 Aug 2021 02:35 #43680
by balinwire
glad you mention rawhide, there was a rubber seal on my hub spindle and it wore a channel in the surface. i suspected the leather was easier on the old alloys. Leather may not seal as well though with modern lube.
11 Aug 2021 01:10 #43679
There are several that will work. CR 21100, CR21103. They are the same ID and OD. CR 21100 ss .438" thick. CR 21103 is .375" thick.
Note: CR is Chicago Rawhide which is now owned by SKF.
- RKF
10 Aug 2021 23:53 #43677
by RKF
The Seal that is pressed into the retaining ring that has notches that holds the wheel bearing in. It goes over the axle.
10 Aug 2021 01:06 #43663
Which seal are you looking for? There on one in the front wheel bearing retaining nut, one in the outter CV joint bell and one on the inner CV joint housing.
- Thank you received: 136
09 Aug 2021 03:21 #43654
Replied by 1748 S on topic Seal
I recall two different size seals for the front axles. But try to get the internal size where the shaft rides and the external size that fits the hub. That that and the old seal to any large bearing supplier and sak for help. I can search my records tomorrow for the size seals and part numbers I used.
- RKF
09 Aug 2021 00:25 #43651
by RKF
Seal was created by RKF
does anyone have info on where to acquire a front axel seal?
My old one says Fitzgerald 84211
