Long distance electrical diagnosis
- wcoye
27 Jul 2021 15:25 #43578
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
Replied by wcoye on topic Long distance electrical diagnosis
Will do! Thanks Mike!
Bill Coye
Westchester 2240A
- wcoye
27 Jul 2021 15:24 #43577
by wcoye
Bill Coye
Westchester 2240A
Hey Terry, Yes I received your email. Many thanx! And sheepishly, yes. Right now the car runs only on the electric pump.
Bill Coye
Westchester 2240A
27 Jul 2021 03:29 #43575
Replied by mikespeed35 on topic Long distance electrical diagnosis
If pump is on could starter Bendix be stuck in ring gear? Try rocking car in gear with ign. off!!!
- Thank you received: 305
27 Jul 2021 03:19 - 27 Jul 2021 05:33 #43574
Replied by Terry Cockerell on topic Long distance electrical diagnosis
Bill as a side issue, does she run on the electric pump all of the time?
Is your mechanical pump still working or not?
PS. HAPPY BIRTHDAY ..................... MATE! Did you receive my email ?
We have having some problems with receiving emails
Last edit: 27 Jul 2021 05:33 by Terry Cockerell. Reason: Spelling error ............. rectified.
- wcoye
27 Jul 2021 01:39 #43573
by wcoye
Bill Coye
Westchester 2240A
I failed to mention the fuel pump is back on when the ignition key is turned on. Another conundrum.
Bill Coye
Westchester 2240A
- Thank you received: 136
27 Jul 2021 00:51 #43572
Replied by 1748 S on topic Long distance electrical diagnosis
Sounds to me like a fuse as Pete posted but... It really sounds like you have no power thru the ignition switch because your not hearing the electric fuel pump. Probably need to start at the battery connections with a test light. Touch the post and the clamp. See if you have continuity. Keep checking the connections to each item thats not working as it worked in the past. Sadly working under behind the dash is going to hurt. Get a good drop light. Some towels to lay on. Removing the front seat is a great way to work under the dash. Or find your best comfortable laying down from the drivers side to reach up to the ignition switch.
26 Jul 2021 23:48 #43571
by pete kelly
Replied by pete kelly on topic Long distance electrical diagnosis
That's a start but no sound from the fuel pump leads me to believe there could be an open fuse in the circuit or a broken wire.
- Joe Holderman
26 Jul 2021 23:31 #43570
by Joe Holderman
Future Cord owner.
Messenger Link: m.me/hotrodjoe
Replied by Joe Holderman on topic Long distance electrical diagnosis
Sounds like you're not getting voltage to the solenoid's relay from the starter button. you can test this theory with a screw driver (short battery voltage to the relay) or use a volt meter and get a reading across the relay coil with and without the starter button pushed.
Future Cord owner.
- wcoye
26 Jul 2021 22:07 #43569
by wcoye
Bill Coye
Westchester 2240A
Long distance electrical diagnosis was created by wcoye
Hi, Have an electrical problem. First of all my car is NOT set up with a Startix. Somewhere a long the line my car was rigged with a regular solenoid. Turn on the ignition, step on the clutch, push the start button and vroom. Until 2 weeks ago when I went through the routine, could hear my electric fuel pump start, but when I pushed the starter button the starter made one turn and silence. Both pump and starter silent. I replaced the solenoid with a NOS part and my battery is in good shape. I haven't found a shop in Raleigh who will look at it, too old. Sooooo what should I look at or for next?
Bill Coye
Westchester 2240A
