- Thank you received: 305
Ebay Trans Case
22 Jul 2021 02:57 - 22 Jul 2021 02:59 #43547
Replied by Terry Cockerell on topic Ebay Trans Case
The ID plate is on the RHS of the cowl.
Attached are some more pictures.
This was owned by Ted Ruhling.
Last edit: 22 Jul 2021 02:59 by Terry Cockerell. Reason: Adding pictures
The following user(s) said Thank You: balinwire
- Thank you received: 19
22 Jul 2021 01:41 - 22 Jul 2021 01:48 #43546
by balinwire
Replied by balinwire on topic Ebay Trans Case
is the data tag under the seat? I would like to see it parked next to a production to see front roof above windshields and the wider body, I can see the solid wheel covers and steering wheel that must have been to expensive to get to production. Looks like the inside cast window frame was a bit wider. Cant see the shifter lever, do see the flat top rear fender protector's. what a clean example, stunning. The glove boxes seem not as square.
Last edit: 22 Jul 2021 01:48 by balinwire.
22 Jul 2021 00:48 - 22 Jul 2021 00:49 #43545
There is a Hand Built Cord in Australia that has Serial No 810 1044 A
It has a banjo steering wheel however I do not know if it is original.
The car has not been looked after very well.
Last edit: 22 Jul 2021 00:49 by Terry Cockerell. Reason: Adding pictures
21 Jul 2021 23:47 - 22 Jul 2021 00:09 #43543
by balinwire
thanks for the link, the first ones were so interesting I have only seen one briefly and it preformed as well as the production model. The firewall was a giveaway and this seems not to have missed anything. I would like to see what a rear sway bar and a rezeppa joint, and a banjo wheel looked like.
Last edit: 22 Jul 2021 00:09 by balinwire.
21 Jul 2021 22:15 - 21 Jul 2021 22:19 #43542
In my previous email I made reference tp the detailed article on Hand Built Cords in The Reunion Book No 2 that was printed in 2010 by the ACD Club and which can be purchased from the Museum in Auburn.
In the article the variations are all listed.
Attached is a copy of that complete article by Bill Bicknell.
Last edit: 21 Jul 2021 22:19 by Terry Cockerell. Reason: Adding Information Sheet
The following user(s) said Thank You: balinwire, Jonathan Richards
21 Jul 2021 21:29 #43541
by balinwire
No eBay APP ID and/or Cert ID defined in Kunena configurationthis is a listing for a three bolt carburetor intake, the photo from the hand built case shows a similar intake, it would be nice to see a list of the different parts used in the hand build's, are the thermostat housings cast iron?
21 Jul 2021 08:22 - 21 Jul 2021 08:25 #43537
Gary it definitely is a very early gearbox case and probably from a Hand Built Cord. It does not have the Interlock hole that you mentioned on the RHS . Also it has an extra bolt on the LHS to hold the reverse idler shaft in place.
Attached is a page from Bill Bicknell's detailed article on hand Built Cords that can be found in The Reunion Book, No 2.
I have no idea why the picture ended up on it's side.
Last edit: 21 Jul 2021 08:25 by Terry Cockerell. Reason: Adding picture
- Thank you received: 136
11 Jul 2021 15:40 #43483
Ebay Trans Case was created by 1748 S
No eBay APP ID and/or Cert ID defined in Kunena configurationI found this trans case yesterday on ebay. I suspect its an early case because it doesn't have the lock pin hole machined into the drivers side. Any opinions?
