Starter motor engage each time I press the clutch
- Tcheri
17 Aug 2021 13:47 #43726
by Tcheri
Replied by Tcheri on topic Starter motor engage each time I press the clutch
Yes indeed. And the problem was that the locknut was loose, so I guess the adjusting screw moved
17 Aug 2021 13:18 #43725
by pete kelly
Replied by pete kelly on topic Starter motor engage each time I press the clutch
Don't forget to replace the locknut.
- Tcheri
17 Aug 2021 09:32 #43724
by Tcheri
Found explanations there :
phpstack-1081784-3880776.cloudwaysapps.c...eeds-repair?start=12
- Tcheri
17 Aug 2021 09:30 #43723
by Tcheri
Indeed, the problem was related to the Startix. 1 half tour, counterclockwise solved the problem.
- Thank you received: 219
16 Jun 2021 18:21 #43344
Replied by JIM.OBRIEN on topic Starter motor engage each time I press the clutch
Hi Therry,
The first question is your generator working properly. If it is then the problem is in the Startix. You will need to adjust it. If you need information on adjusting it let me know and I'll send it to you.
The following user(s) said Thank You: Tcheri
- Thank you received: 136
15 Jun 2021 15:43 #43341
Replied by 1748 S on topic Starter motor engage each time I press the clutch
You may have an issue with the startix or in the wiring from the startix to the generator
- Tcheri
15 Jun 2021 13:35 #43337
by Tcheri
Starter motor engage each time I press the clutch was created by Tcheri
Hello,
Before it was random, now each time, the starter engage each time the clutch is pressed.
I guess the signal that the engine is running is not received.
Where should I look ?
Many thanks
Thierry
Many thanks
Thierry
