Windshield seals
  • Panacea Limousine
  • Panacea Limousine's Avatar Topic Author
  • Visitor
  • Visitor
31 Mar 2003 02:42 #25 by Panacea Limousine
Panacea Limousine replied the topic: Windshield Seals
Mr. Dutch!
Thank you for your post. I would be most interested in your findings when you get into replacing the seals. Yes, my sedan has the roll out feature for the "A/C," on the windshields. I am just not seeing the screws or hardware holding the seals on the frame. :rolleyes:<!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":?:" title="Question" /><!-- s:?: --> Thanks again!
"D"
  • Dutch Jacobs
  • Dutch Jacobs's Avatar Topic Author
  • Visitor
  • Visitor
31 Mar 2003 03:06 #29 by Dutch Jacobs
Dutch Jacobs replied the topic:
Look underneath the bottom edge, once they are opened all the way.
-Use a mirror if necessary.
The top screws should be accessable once the bottom is freed up, because the window can swing out to get at them!
Ah - be gentle, of course....
:D
~Dutch
  • Josh Malks
  • Josh Malks's Avatar
  • ACD Club Past President
18 Apr 2003 18:13 #118 by Josh Malks
Josh Malks replied the topic:
There are NO screws holding the windshield weatherseals in place on the Cord sedan.
18 Apr 2003 20:10 #120 by PushnFords
PushnFords replied the topic: Seal Installation
I just installed a new set of windshield frames and seals in a '37 Beverly. The frames themselves are held in by two hinges at the top (three screws each) and two screws hold the bottom. Undo the bottom, swing the windshield up, and undo the hinges.
The new windshield frames should hold themselves into the channel of the frame. Line the straight sections up and then start working around the outside. You may have to pull them around a little to take out slack. If they don't want to stay, apply a slight amount of weatherstrip adhesive. I used 3M black in a couple spots on one seal.
Derek
  • Panacea Limousine
  • Visitor
  • Visitor
18 Apr 2003 21:00 #121 by Panacea Limousine
Dereck: You rock!!! :DThank you so much. After I get those installed, I intend to work on getting the driver's windshield wiper motor out!
"D"
18 Apr 2003 22:45 #122 by PushnFords
PushnFords replied the topic: Re: Seal Installation
The second paragraph should say the new windshield rubbers should hold themselves into the channel......but you probably guessed that! This would also be a good time to change the screws to stainless if they aren't. They can be hard to get out!
Derek
PushnFords wrote: I just installed a new set of windshield frames and seals in a '37 Beverly. The frames themselves are held in by two hinges at the top (three screws each) and two screws hold the bottom. Undo the bottom, swing the windshield up, and undo the hinges.
Derek
Time to create page: 0.081 seconds
