Windshield seals
- PushnFords
Derek
PushnFords wrote: I just installed a new set of windshield frames and seals in a '37 Beverly. The frames themselves are held in by two hinges at the top (three screws each) and two screws hold the bottom. Undo the bottom, swing the windshield up, and undo the hinges.
The new windshield frames should hold themselves into the channel of the frame. Line the straight sections up and then start working around the outside. You may have to pull them around a little to take out slack. If they don't want to stay, apply a slight amount of weatherstrip adhesive. I used 3M black in a couple spots on one seal.
Derek
- Panacea Limousine
"D"
- PushnFords
Derek
- Dutch Jacobs
-Use a mirror if necessary.
The top screws should be accessable once the bottom is freed up, because the window can swing out to get at them!
Ah - be gentle, of course....
~Dutch
- Panacea Limousine
Thank you for your post. I would be most interested in your findings when you get into replacing the seals. Yes, my sedan has the roll out feature for the "A/C," on the windshields. I am just not seeing the screws or hardware holding the seals on the frame. :rolleyes: <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: --> Thanks again!
"D"
- Dutch Jacobs
I'm going to be replacing all of the rubber parts on mine, and from what I could see it appeared fairly simple.
- Assuming I can find the screws that were in it! Someone before me already went there, and left everything apart.
~Dutch
- Panacea Limousine
- Bill Hummel
- Panacea Limousine
"D"
- Bill Hummel
Panacea Limousine wrote: I am about to take the windshields out of my 37 Beverly to replace the seals. Has anyone done this lately and can caution me about it, except that I shouldn't drop them?!!! <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
"D"
I would think that any reputable Windshield repair company can replace these for you. Am I wrong? What does Stan recommend?
- Panacea Limousine
"D"
