Adjustment Knob on 660Z delco distributor
30 Jul 2016 11:45 #31431
Replied by Curt Schulze on topic Re: Adjustment Knob on 660Z delco distributor
Garden variety wheel bearing grease.
Personally, I would not have installed a Pertronix ignition .
1- The modification is visual.
2- Go over to the AACA site and read about problems with them.
3- Points are available at NAPA and are very easy to adjust.
- curtiss
29 Jul 2016 20:07 #31430
by curtiss
Replied by curtiss on topic Re: Adjustment Knob on 660Z delco distributor
Any particular grease that this takes?
29 Jul 2016 18:37 #31428
by pete kelly
Replied by pete kelly on topic Re: Adjustment Knob on 660Z delco distributor
You are correct; the knob is a greaser and is turned periodically to grease the distributor.
Pete
Pete
29 Jul 2016 15:14 #31427
Replied by 1748 S on topic Re: Adjustment Knob on 660Z delco distributor
I'm not an Auburn expert or even close but I believe this knob is how the grease gets forced into the bushing internally. I recall reading something some time back at a mileage point to adjust and to refill this cavity with grease. Hope others more able to comment on what I have posted. Spreading bad information is not what I want to do but will be watching other answers.
- curtiss
29 Jul 2016 13:34 #31425
by curtiss
Adjustment Knob on 660Z delco distributor was created by curtiss
I just installed a 660Z delco distributor back into out 8-98 replacing an incorrect dist. I also installed Pertronix and it runs great but I have a question.
What is the adjusting knob on the side of the distributor for and now that I have converted to electronic ignition does it have any function? When I installed it I turned it all the way in but am not sure if that was the right thing to do.
