Early Ross steering box sector shaft peg
- Ivor
30 Aug 2015 22:10 #30176
by Ivor
Replied by Ivor on topic Re: Early Ross steering box sector shaft peg
Thanks Mark, PM sent.
Ivor.
Ivor.
28 Aug 2015 14:18 #30159
by ilikescars
Replied by ilikescars on topic Re: Early Ross steering box sector shaft peg
I have some used sectors that you might be able to use. Let me know
- Ivor
28 Aug 2015 00:21 #30155
by Ivor
Early Ross steering box sector shaft peg was created by Ivor
The Ross steering box fitted to Auburn cars from mid to late 20's has a one piece sector shaft and peg. The problem is when this peg is worn correct steering adjustment is impossible. Is anyone aware of a supplier of replacement case hardened pegs for these steering boxes that would allow the old peg to be ground off then the sector shaft flange drilled and a new peg fitted (similar to military jeep Ross steering). The attached photos show typical wear found on this type of steering box. The diameter of the peg at the small end is 0.437" large end 0.570" and it extends 0.375". Any advice appreciated.
