Distributor cap problem
07 Jun 2015 14:10 #29705
by ilikescars
Replied by ilikescars on topic Re: Distributor cap problem
Yes, 1748, I also thought of that. But the unit fits into a brass sleeve that has plenty of conductivity around the perimeter of the spring-loaded carbon. <!-- s:idea: --><img src="{SMILIES_PATH}/icon_idea.gif" alt=":idea:" title="Idea" /><!-- s:idea: -->
05 Jun 2015 17:43 #29703
Replied by 1748 S on topic Re: Distributor cap problem
I find this an interesting topic. A few weeks ago I was visiting with a club member that owns 11 Cords. He showed me something interesting about these carbon pieces in the 812 distributor caps. He said just open up a "C" battery and remove the carbon. Cut it down to fit and you're all set. As for the spring I have no idea. also as for the JB Weld to hold the spring in place I would be cautious about that. I do not know what the conductivity is for the JB Weld. That spring needs to allow coil voltage to flow thru the spring to the carbon and then thru the carbon to the rotor. Otherwise this seems like a great restoration tip that should be added to the forum about Restoration Tips..
31 May 2015 17:32 #29684
by ilikescars
JM: Yes, I thought that might be the reason it was coming loose, good point. I used a small dab of JB Weld and jammed the spring back into the hole. Then used JB weld to stick the carbon back onto the spring. Let it cure overnight and tried it. Works well so far. (I also put a small amount of electrical grease on the rotor contact to reduce friction)
31 May 2015 16:22 #29683
Replied by johnmereness on topic Re: Distributor cap problem
Here is an engineering question - I know several non-Auburn cars used look alike caps, though does the distributor turn in a different direction on those cars - the spring could be acting as a "thread" (like a nut or bolt) and one direction could tighten and the other direction could loosen. I had a discussion with Curt a couple of months ago and he said he has had several come loose after a few miles and has not really been successful with these caps of getting the carbon piece to stay in thereafter.
30 May 2015 03:42 #29676
Replied by mikespeed35 on topic Re: Distributor cap problem
I have bought caps at Hershey that were cheap, $1 to $5. that had the right size carbon.
Cordially Mike
Cordially Mike
29 May 2015 20:26 #29674
by ilikescars
Thanks, Pete! Never would have thought they'd be available thru standard auto parts stores.
29 May 2015 13:20 #29670
by pete kelly
Replied by pete kelly on topic Re: Distributor cap problem
NAPA has them
Pete
Pete
29 May 2015 12:29 #29669
by ilikescars
Distributor cap problem was created by ilikescars
In the past, I have purchased NOS distributor caps off Ebay. (1935-36 Auburn) They look new, but for some reason, the little spring-loaded carbon contact has fallen out of two of my caps after installation & running. Has anyone been able to source these little carbons w/spring? Seems a shame to discard the entire cap because of this defect...
