Oil for 2speed rear axle - EP or not ?
21 May 2014 02:30 #27554
Replied by mikespeed35 on topic Oil for 2speed rear axle - EP or not ?
Muncie 4 spds. have bronze sycros. and use GL-5.
- Auburn
20 May 2014 03:51 #27546
by Auburn
Replied by Auburn on topic Oil for 2speed rear axle - EP or not ?
Thanks for the replies
I did some further research and it appears that not all GL-5 oils are equally corrosive to yellow metals.
So I bought one can of 140W single weight GL-5, dipped a new copper washer in it and will see if the color changes over time, or if I can see some pitting take place on its surface.
18 May 2014 11:40 #27533
Replied by Curt Schulze on topic Dual Ratio
I believe bushings E61858 are copper and spacer E61857 is brass.
I use 89-90 hipoid gear lube which can be purchased at NAPA. If you have not gone through the Dual Ratio, I would suggest so, it is the weakest link in the chain.
17 May 2014 20:13 #27531
I use 90W140 GL-5 in my differential. I don't remember any yellow metal in the diff.
- Auburn
15 May 2014 00:55 #27520
by Auburn
Oil for 2speed rear axle - EP or not ? was created by Auburn
The technical bulletins keep mentioning to only use a "special" 2speed differential gear oil but not much data is provided on it.
The code in those bulletins has 140EP so I assume that this is 140 weight EP..
Can we use a GL5 EP - extreme pressure - oil with the sulfur additive, or does the axle contain yellow metal parts which would call for a non-EP oil such as a GL1.
Rob
Rob
