1931 898 Sedan Auburn Oil Filter
- olvette64
29 Jan 2013 01:57 #24402
by olvette64
Replied by olvette64 on topic 1931 oil filter
Thank you all for the replies. I found a canister type on ebay that was originally used on a Willys and it looks like it will mount in my original oil filter mount.
- karman1930
22 Jan 2013 01:49 #24353
by karman1930
Replied by karman1930 on topic 1931 898 Sedan Auburn Oil Filter
I used a ford v-8 canister that takes a changeable element like Mike described. The replacement elements are available at NAPA. Give me your email and ill send you a picture of the one I put on my brougham and the refill part number.
Tom
Tom
- Jack
17 Jan 2013 22:21 #24332
by Jack
Change is inevitable, success optional.
Replied by Jack on topic 1931 898 Sedan Auburn Oil Filter
A gentleman by the name of Burr Ripley makes replacement oil filters from billet aluminum that have modern spinoff filters inside. He makes several different stiles, so be sure to indicate the stile you want. His number. 607-844-8473.
Jack
Jack
- Mike Dube
16 Jan 2013 17:13 #24320
by Mike Dube
8-100A
Replied by Mike Dube on topic 1931 898 Sedan Auburn Oil Filter
That's what I use, found a NOS Purolator @ Hershey a number of years ago, and buy replacement elements @ NAPA or online. They are pretty generic, the top cover is held on with a center bolt and you get new gaskets/seals with the replacement elements. You can probably find something on ebay or the like, if you don't do swap meets.
8-100A
- olvette64
12 Jan 2013 22:43 #24303
by olvette64
1931 898 Sedan Auburn Oil Filter was created by olvette64
Does anyone have any recommendations on what to use for a replacement oil filter?
Based on photos that I have seen I believe the filter on my car is an original type sealed canister filter. I have read postings that you can get a tractor canister filter or an industrial canister type filter that uses removable elements.
