1932 8-100A carburetor-HELP
  • pwright
  • pwright's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
19 Oct 2003 21:01 #920 by pwright
pwright created the topic: 1932 8-100A carburetor-HELP
Well, I've rebuilt my fuel pump and it stopped the leaking. Now I have a regular dripping of gas from the underside of the carb. The gas is dripping from the bottom of the air intake area. Any ideas on what is causing my problem? I can't believe that these problems have developed back to back in a very short period of time. Oh well. Pete
20 Oct 2003 02:35 #921 by Kees Richie
Kees Richie replied the topic: 1932 Carburetor
Your float needle at the inlet of the carb. does not close if dripping occur.
Dirt , water or sludge will prevent the needle from closing.
8 cylinder nut
  • Auburn/Cord Parts
  • Auburn/Cord Parts's Avatar
20 Oct 2003 16:04 #929 by Auburn/Cord Parts
Auburn/Cord Parts replied the topic: Re: 1932 8-100A carburetor-HELP
The advice is correct - either clean or replace the needle and seat in the carb. The old Auburn will settle down and run better too!
Stan
  • pwright
  • ACD Club Member
  • ACD Club Member
20 Oct 2003 23:09 #931 by pwright
pwright replied the topic:
Thanks to all for the help! Problem solved. It was a piece of trash in the needle valve. Runs like a top again. Pete
Time to create page: 0.062 seconds
