- Thank you received: 7
Alternative to Penrite for steering box
- pfree3233
14 May 2019 01:30 - 15 May 2019 01:47 #37190
by pfree3233
Replied by pfree3233 on topic Alternative to Penrite for steering box
I'm not sure they are the same:
Per Super S :
Super S Cotton Picker Spindle Grease 00 is a smooth textured, corrosion preventive grease manufactured with a special low viscosity, low pour point base oil with a lithium thickener, as well as rust and oxidation inhibitors. It is recommended for industrial and agricultural applications calling for a low consistency product with low operating temperature properties. Super S NLGI 00 Grease meets or exceeds the John Deere JDN-360 and JDN-380 specific cautions for cotton picker spindle lubricants. It is widely used in gearboxes on bush hog type cutters and some gear cases on riding lawn mowers.
Temperature Range: -20° F to 200° F
Flash Point: >284° F (COC)
Dropping Point: 320° F
Per Penrites Website:
Penrite Steering Box Lube is an Extreme Pressure, NLGI 00, lithium based grease, blended with effective anti-wear, rust and Oxidation Inhibitors. It is a High Viscosity, self-levelling grease that features non-corrosive extreme pressure (EP) additives to provide enhanced film strength protection.
Penrite Steering Box Lube has a normal operating temperature range from -20º to 130º.
Hope this helps
Pat
Per Super S :
Hope this helps
Pat
Last edit: 15 May 2019 01:47 by pfree3233.
10 Nov 2018 19:04 #35935
Replied by Curt Schulze on topic Alternative to Penrite for steering box
John, I posted that question out on AACA look in general discussion.
10 Nov 2018 17:20 #35932
Replied by johnmereness on topic Alternative to Penrite for steering box
I will give it some research !
06 Nov 2018 23:58 #35917
Replied by 1748 S on topic Alternative to Penrite for steering box
Thank you for the explanation. I may try this suggestion mostly because of the squeeze bottle idea.
06 Nov 2018 21:52 #35915
by ilikescars
Replied by ilikescars on topic Alternative to Penrite for steering box
Many times less expensive. ($5 for a full quart!) I compared both brands, and they are the same in appearance and viscosity. Also, having the squeeze bottle is super helpful: no need to heat up the grease before-hand.
05 Nov 2018 22:38 #35900
Am interested why you suggest this instead of Penrite. Reason I ask is eventually I will need something for my 37 Beverly steering box after re seal or rebuild. But thanks for this information too.
05 Nov 2018 15:34 - 05 Nov 2018 22:10 #35898
by ilikescars
Alternative to Penrite for steering box was created by ilikescars
Much less expensive, but basically the same litium-based pourable grease product: Super S Cotton picker Spindle Grease "00"
Available at Tractor Supply. SKU number 105682899
It's in a squeeze bottle, so much easier to shoot into that small fill-hole in your Ross steering box
Last edit: 05 Nov 2018 22:10 by ilikescars.
