Cord 810/812 6 plus 6 Optima conversion
- Premium Member
With the stub frame and all the sheet metal bolted to the main body there are lots of connections the electricity can or has to go thru. The problem is there is 85 years of rust and corrosion in there. The other cause is during the restoration process people forget or don't realize that the stub frame connection to the main body is also an electrical connection. It only takes about 1 ohm of resistance to have the starter turn slowly, two ohms and you can't crank over the engine. There has to be a good solid electrical connection. If the stub frame is removed, painted and reinstalled there may not be a good enough connection to start the car, it may be good enough for the lights, running the car or charging the battery.
The easy fix is running a large grounding cable (00) from the battery to the mounting bolt on the starter.
As long as the electrical system is good 6 volts is plenty to start the car and for everything to work properly.
- Frenchsic
- Frenchsic
Ken
- dtitus
- Junior Member
I will greatly appreciate if you could please share Mr. Allan McCrary.'s email address. I need help with regard to Right Hand Drive Bell Housing for my 1932 Auburn V12.
Best wishes.
Diljeet Titus
- Greg Frownfelter
they are powerful, long lastinI have had a few that gave 10 years service
they are capable of long shelf life with no attention
battery tenders are recommened not trickle chargers
to bad they are expensive but buy 2 or 3 regulars in 10 years
greg
- ETHAN ALLEN TURNER
- Bill Hummel
Good find, Ethan.
I raised my battery so it would not hit the high spot coming off the street to my driveway. As I have built my Cord to be a driver it is protection when out on the road.
- pkschafer
- pkschafer
- Pat Leahy
- Thank you received: 27
Pat Leahy
- pkschafer
