- Thank you received: 7
More sensitive hydraulic brake light switch needed
- Joel
Topic Author
- ACD Club Member
18 May 2022 20:08 #45432
by Joel
Replied by Joel on topic More sensitive hydraulic brake light switch needed
Well, I went ahead and ordered the Ron Francis switch from Summit racing. I'll let you know how it works out. Thanks for the replies!
- Joel
Topic Author
- ACD Club Member
18 May 2022 20:12 #45433
by Joel
I also ordered 6 volt LED dual filament bulbs. 1 red for the right hand light that has a clear lense. The switch has a 5 amp limit, and the led bulbs have very low amp draw.
- Thank you received: 162
19 May 2022 03:42 #45436
Replied by mikespeed35 on topic More sensitive hydraulic brake light switch needed
The problem with LED is they won't work with turn signals unless you make modifications I have been told. Don't have personal experience.
- Joel
Topic Author
- ACD Club Member
19 May 2022 04:25 #45438
by Joel
Mike, this car doesn't have turn signals, so not an issue. But I do have led bulbs in my hot rod. They don't draw enough current to operate the bimetallic thermal switch in a mechanical flasher. But they make a solid state flasher that works. That car is 12 volt. I'm not sure if that flasher would work in a 6 volt car.
20 May 2022 04:14 #45443
It should Joel. No one understands your hand out the window.
- Joel
Topic Author
- ACD Club Member
20 May 2022 04:27 #45444
by Joel
Your right on that Mike. I suppose blinkers will go onto the to-do list.
Time to create page: 0.139 seconds
