More sensitive hydraulic brake light switch needed
- pfree3233
- Thank you received: 7
- pfree3233
- pfree3233
- Joel
- pfree3233
- Joel
- Joel
- Joel
- Joel
- pfree3233
Hot Rod companies such as Painless wiring and Ron Francis Wiring have low pressure brake light switches. They work in the range of about 20-50 lbs. You may want to try Yogis 800 373 1937, they carry both lines. Good luck Pat
- Joel
On my 1929 Cord L29, the brake light doesn't come on unless I'm really stomping on the brakes. I have a similar situation in my 49 Plymouth, but not quite as bad.
Does anybody know of a very sensitive hydraulic brake light switch, something that would activate with just barely a touch of the brakes? Preferably something that could be found locally if a guy had the part number or the application.
I have considered installing a mechanical switch on the pedal somehow, but it seems it would be much cleaner and simpler to replace the hydraulic switch with a more sensitive one.
Thanks very much, Joel
