Ring n Pinion Gear Setup
  • 1748 S
  • ACD Club Member
  • ACD Club Member
04 Jun 2020 21:14 #40304 by 1748 S
Ring n Pinion Gear Setup was created by 1748 S
I have been searching for the proper procedures for setting the rin n pinion gear in the trans housing. I have not found what I'm looking for. I realize the shim pack under the bottom pinion shaft front bearing retainer clip. But what about the side bearing setup?on the ring gear? I also do not know how what the contact pattern is supposed to look like.
  • JIM.OBRIEN
  • Frequent Forum Contributor
05 Jun 2020 00:12 #40305 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Ring n Pinion Gear Setup
The Cord Transmission manual tells you how to do it.
  • 1748 S
  • ACD Club Member
  • ACD Club Member
05 Jun 2020 13:34 #40307 by 1748 S
Replied by 1748 S on topic Ring n Pinion Gear Setup
thanks Jim. Are you referring to the new trans booklet or the older one many of us use now?
  • JIM.OBRIEN
09 Jun 2020 01:48 #40329 by JIM.OBRIEN
It's in the existing booklet (and in the updated one). Look under the assembly instructions, Section 8 Step 28
Time to create page: 0.053 seconds
