Cam Shaft Follower "Rollers & Pins" REQUIRED.
28 May 2020 18:21 #40293
Replied by 1748 S on topic Cam Shaft Follower "Rollers & Pins" REQUIRED.
Terry here is some pictures of my modified rocker arms. Am not sure but I believe the cam followers were the bushing type bearings where mine are now a roller needle bearing follower.But the shaft end is still the bushing type bearing for support. I know my modification was done sometime in the 1961 time frame and not exactly sure of it. I know the tappet adjuster was ground as was every valve end. I recall someone mentioned Porsche adjusters could be made to work better than the originals too.
The following user(s) said Thank You: Terry Cockerell
28 May 2020 17:58 #40292
Replied by JIM.OBRIEN on topic Cam Shaft Follower "Rollers & Pins" REQUIRED.
Terry, There is actually less pressure drop. You are no longer feeding 15 bushings (cam followers). The needle bearing us splash lubrication.
- Thank you received: 302
28 May 2020 10:25 #40286
Replied by Terry Cockerell on topic Cam Shaft Follower "Rollers & Pins" REQUIRED.
Thanks Jim but I think I can get most of that work done in Australia.
The exchange rate plus shipping usually doubles the US price.
One question I have with using needle rollers is "Does this cause more of a pressure drop in the lubrication system compared to the original plain bushes?"
28 May 2020 00:11 #40282
Terry,
Send your old rockers and shafts to George. He rebuilds them with the needle bearing followers, rechromed the shafts, etc. When they come back they are ready to install. He does very nice work!
27 May 2020 22:22 #40281
by uconn_1965
Replied by uconn_1965 on topic Cam Shaft Follower "Rollers & Pins" REQUIRED.
Highly recommend George Arakelian. He is in the directory from Michigan.
27 May 2020 21:33 #40280
Cam Shaft Follower "Rollers & Pins" REQUIRED. was created by Terry Cockerell
Can anybody direct me to a good supplier of cam shaft follower "Rollers & Pins"?
I know EGGE can , eventually supply them but I am reluctant to deal with them again after they sent a set of Cord pistons with the gudgeon pins holes 1/4" lower than required. No apologies , business as usual, send them back.
