Throwout Bearing
16 May 2020 16:42 #40183
Replied by 1748 S on topic Throwout Bearing
Thanks George. This clear explanation sure helps. Its answers like this that makes our cars seem simple.
- George van Nostrand
- Thank you received: 35
16 May 2020 16:13 #40182
by George van Nostrand
Replied by George van Nostrand on topic Throwout Bearing
Gary I found JK Howell's directions. 1. Remove release bearing guide and remove 1/4" to 9/32" from face 2. reinstall guide. 3. install two seals into hole in clutch housing , in front of guide. lips facing transmission. Grease sealing lips and use care when installing transmission.
14 May 2020 19:37 #40175
by uconn_1965
Replied by uconn_1965 on topic Throwout Bearing
14 May 2020 17:39 #40172
Throwout Bearing was created by 1748 S
Our 810 812 Cord clutch throw out bearings ride on a sleeve. We can purchase two seals from Stan so I did. No directions other what is printed in the catalog telling to "some machining required"....My question is which end do I machine so the seals fit? I suspect its the end that bolts to the bell housing differential wall behind the clutch n throw out bearing. Any ideas?
