Rod Bearing Clearance
12 May 2020 02:52 #40152
Replied by 1748 S on topic Rod Bearing Clearance
I was going thru my files and found this from Stan. Its the same and more than what has been posted here. Hope it helps everyone during rebuilds.
- Thank you received: 302
04 May 2020 01:34 #40100
Replied by Terry Cockerell on topic Rod Bearing Clearance
Tom.
May I suggest that you get a copy of the Cord 810 812 Service Manual from the Museum in Auburn. It has a huge amount of useful information on our beloved Cords.
From the book the Factory recommended clearances are as follows:
Main bearings 0.0015" to 0.00375"
Thrust bearing side clearance 0.004" to 0.009"
Connecting rod bearings 0.001" to 0.0015"
- Ivor
03 May 2020 08:03 #40096
by Ivor
Replied by Ivor on topic Rod Bearing Clearance
Hello Tom, I do not own a Cord though the nominal clearance for babbitt big end bearings around the size of your cord crankshaft is around 0.0015" to 0.003" As Mike highlighted there is a difference between the clearance for the Main bearings which is is around 0.002 " to .00325" these age general engineering clearances, I am sure one of our Cord members will give you the recommended factory cord clearances.
Ivor.
Ivor.
03 May 2020 05:28 #40095
Replied by mikespeed35 on topic Rod Bearing Clearance
I presume you mean the rod and main bearings?
- twright3
02 May 2020 09:40 #40093
by twright3
Rod Bearing Clearance was created by twright3
What is the appropriate clearance between the crankshaft rod throws and and connecting rod bearing? Thanks, Tom
