Gearbox Oil Pump Pressure Relief Valve Spring
  • Frenchsic
  • Visitor
  • Guest
06 Dec 2020 18:25 #41712 by Frenchsic
Replied by Frenchsic on topic Gearbox Oil Pump Pressure Relief Valve Spring
Jim, as I don't have any shop manual info yet, what is the pressure this releases at?
Thanks, Ken - 812 SC
  • 1748 S
  • Platinum Forum User
28 Feb 2020 20:55 - 28 Feb 2020 20:58 #39624 by 1748 S
Thanks Terry. This has been my plan but... I'm trying to "feel" the seat or see what it looks like deep inside the cover. It amazes be the "repairs" I have found in this car restoration. I tested the plug to seat seal with brakclean and nothing leaked by. Am hoping the mechanic didn't modify the seat to accept the plug.
Last edit: 28 Feb 2020 20:58 by 1748 S.
  • Terry Cockerell
  • Elite Forum User
28 Feb 2020 19:28 #39621 by Terry Cockerell
Replied by Terry Cockerell on topic Gearbox Oil Pump Pressure Relief Valve Spring
Gary it looks like the last guy who worked on the pump lost the ball and substituted the bit of rod. I would go back to using a ball. Your spring looks the same as in Jim O'Brien's picture.
  • 1748 S
28 Feb 2020 17:06 #39618 by 1748 S
Jim and Terry. I "found" a zip lock bag of gears and parts to my original trans oil pump. From my best recall I did not have a ball but had this plug to be held against the seat for pressure regulation. It seals very well but I plan to test it better before commiting it to the design. Have either of you seen a plug instead of the ball?
  • Terry Cockerell
  • Elite Forum User
27 Feb 2020 20:28 #39613 by Terry Cockerell
Thanks for the dimensions and picture Jim, I now have exactly what I needed.
  • JIM.OBRIEN
  • Premium Forum User
27 Feb 2020 16:30 #39611 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Gearbox Oil Pump Pressure Relief Valve Spring
The spring holds a ball against a seat.
  • 1748 S
27 Feb 2020 16:25 #39610 by 1748 S
Thanks Jim.. I have seen this on my work bench...Isn't there a sliding plug type seat that this spring holds closed till a certain pressure is reached?
  • JIM.OBRIEN
27 Feb 2020 16:17 - 27 Feb 2020 16:18 #39607 by JIM.OBRIEN
Transmission oil pump relief spring
OD - 0.320"
Length - 1 1/16"
Wire Diameter - 0.035"
Active coils - 6
Ends Squared and Ground
Last edit: 27 Feb 2020 16:18 by JIM.OBRIEN.
  • Terry Cockerell
  • Elite Forum User
27 Feb 2020 04:07 #39594 by Terry Cockerell
Thanks Jim.
  • JIM.OBRIEN
27 Feb 2020 02:33 #39591 by JIM.OBRIEN
I'll get you the info tomorrow
  • Terry Cockerell
  • Elite Forum User
26 Feb 2020 03:18 #39586 by Terry Cockerell
Thanks Gary. Hopefully somebody will give us the desired information.
  • 1748 S
25 Feb 2020 23:32 #39583 by 1748 S
Sorry Terry. I spend nearly three hours searching for this spring. But it has found a hiding place and wont come out to play. I recall Henry used to test run the pumps he rebuilt but no idea what he used as a test bench. Maybe he just filled the pump with oil. Bolted it to a block plate and ran the pump watching a test gauge. Adjusted for pressures. Will continue looking later.
  • Terry Cockerell
  • Elite Forum User
25 Feb 2020 19:01 - 25 Feb 2020 19:02 #39580 by Terry Cockerell
Gearbox Oil Pump Pressure Relief Valve Spring was created by Terry Cockerell
My gearbox pressure relief valve appears not have the correct spring. What I have is a fine spring with a spacer behind it.
The original item has Part No B11026
Can anybody give me the overall dimensions of the correct spring?
Length, outside diameter, number of coils and wire diameter.
Thanks in advance.
Last edit: 25 Feb 2020 19:02 by Terry Cockerell. Reason: Revising text
